Drill Doctor - Tools - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 04:34 AM   #1
Drill Doctor
Anyone ever use the Drill Doctor? Been thinking about getting one, but not sure if it would be worth it.
http://www.cpodrilldoctor.com/
Always read good reviews of them online, and I NEED a new toy...
itin1200 is offline   Reply With Quote
Old 05-04-2010, 07:31 AM   #2
I have one and like it.
oberkc is offline   Reply With Quote
Old 05-04-2010, 08:41 AM   #3
I am a "tool & die" maker. I bought ther best, a few years ago, because of failing eyesight and unsteady hands.
Could never get the Chuck to clamp the drill bit straight. If you can check one out before buying, just clamp the bit and see if it can be moved back and forth (off centered). They may have corrected this "micky mouse chuck" by now.
I took mine back and just buy new smaller bits when needed. You can buy a lot of quality bits for the price!
Giles is offline   Reply With Quote
Old 05-04-2010, 06:37 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
it,
Gary Katz bought one years ago so I had to order one but I never got around to actually using it.
HF has come out with a couple of Bit sharpeners that work on a different principle. The first one is Electric and has a turret that holds bits from just a hair larger than 1/8" to just a hair larger than 3/8" for $30
http://www.harborfreight.com/electri...ner-90287.html
The second sharpener is more for field use and is powered by the users drill. It sharpens drills from just a hair over 1/16" up to 1/2". Pretty cool at $5
http://www.harborfreight.com/drill-b...ner-98061.html
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-08-2010, 06:55 PM   #5
Household Handyman
Rewards Points: 1,408
I'm a retired machinist/mold repairman and my kids gave me a "Drill Doctor" for Christmas some years ago. I actually like it. I have not had a problem with the chuck holding the drill bits straight, but am not over excited about the way the unit locates the drill bit cutting edge to sharpen it. I do look closely, through bi-focals, to assure the cutting edge is lined up properly. I had to learn how to sharpen drill bits, small or large, by hand years ago and I really appreciate this tool at home. I'd rate it an 8 out of a possible 10. David
Old 05-08-2010, 07:09 PM   #6
the Musigician
DangerMouse's Avatar
I just grind 'em razor sharp by hand... Most of my bits are larger than 1/2".... and spade bits too.
DM
Old 05-09-2010, 12:06 AM   #7
Rewards Points: 252
I got one as a gift a while back, and for years I never touched it. However, one day when I got frustrated with a dull bit and didn't have a backup, I used the thing. Loved it!
Now, whenever I have a project requiring a bit of drilling, I usually pull out the Drill Doctor and sharpen the bit(s) before getting started! It's great to have sharp bits, and I have had no problems using the unit. (So far, I still don't need reading glasses).
That all said: I probably wouldn't buy one for myself, since I'm too cheap! As Giles said, you can buy plenty of bits for the price. But you might consider adding it to the wish list, next time someone asks...
Itsdanf is offline   Reply With Quote
Old 05-14-2010, 04:44 AM   #8
Thanks for the replies everyone. Decided to spend the money on this instead.
http://www.cpotools.com/factory-reco...rotary-hammers
I think the Drill Doctor is something I wouldn't buy for myself, but if someone were to buy me one...
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 02:46 AM
DH wants to buy me a Drill Doctor. Good idea/Bad idea? Leah Frances Tools 4 02-28-2009 01:46 PM
