Drill Bits For Wood/timber - Tools - DIY Chatroom Home Improvement Forum
Old 01-31-2008, 07:58 PM   #1
Drill bits for wood/timber
I'm planning to install a door viewer, the one I'm looking at requires a 13mm hole on the door, now I wonder which drill bit to get for this job:
1. a regular twist bit: it's relatively costly
2. a brad point bit: such as this one
3. a spade bit: the cheapest option
Obviously I don't want to mess this one up and end up replacing the whole door. So I'm interested to know which drill bit is easy to operate and produces a clean cut.
TIA
peter1 is offline   Reply With Quote
Old 01-31-2008, 08:16 PM   #2
drill a pilot hole (1/4" or so) all the way thru (nice and str8). then use whatever you want - drill from each side towards middle. as long as the bit is sharp you will have a nice hole, even with a spade (for cheap doors the auger bit would actually probably tear a knarly hole)
nacko is offline   Reply With Quote
Old 02-01-2008, 08:13 AM   #3
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
What he said but use only an 1/8" for the first hole this keeps the spade bit in the center wiht less wobble
Kingfisher is offline   Reply With Quote
Old 02-01-2008, 10:37 AM   #4
Rewards Points: 150
Have your brother-in-law do this job.
He probably has a $2.00 1/2" drill bit.
JGarth is offline   Reply With Quote
Old 02-02-2008, 11:47 PM   #5
Hold a board tight to the other side paying attention where the bit will come out so you dont spike your hand. This will eliminate blowout.
Joining_Heads is offline   Reply With Quote
Old 02-05-2008, 06:57 PM   #6
remodeling pro
Better off just watching for the point of the spade bit to emerge, then complete the hole from the other side, or drill a 1/8" pilot hole as suggested and just drill as deep as you want from both sides. Not only will you get a straighter hole, but there is much less chance of the bit grabbing and wrenching your wrist or worse yet, wrenching out of the hole and damaging the door.
Spade bit is the most economical at a couple of $. Regular twist bits are a bad choice for wood, especially the larger sizes, as they tend to bite and pull chunks out of the surface.
troubleseeker is offline   Reply With Quote
Old 02-05-2008, 11:39 PM   #7
Oh.. I didnt realize the TS wanted info on spade bits
Old 02-06-2008, 07:45 AM   #8
waiting for spring
arichard21's Avatar
Rewards Points: 150
TIA
I like these bits for drilling for electrical in studs, but i agree with others that they aren't meant for something like this... they take massive chinks pf wood with them.
arichard21 is offline   Reply With Quote
Old 02-19-2008, 06:46 AM   #9
When is fishing season?
CowboyAndy's Avatar
I am a fan of the auger bits, but find that the first cutting blade of the bit (not the self feeder - is that what it is called?) dulls easy. What is the proper way to sharpen them?
CowboyAndy is offline   Reply With Quote
Old 02-19-2008, 09:16 AM   #10
Is the door one with a solid core? Or, might it just be filled with a compound? The advice about tearout and blowout is good and you want to be especially careful if its NOT an actual 100% solid wood door. You could get past the veneer or first wooden layer, hit a softer material and allow the drill bit to jump off-line through to the other side and punch its way through the other side instead of actually drilling the hole. Slow and steady with a sharp bit. Spade bits are great for solid wood but drilling from both sides will always produce better, sharper and cleaner results.
End Grain is offline   Reply With Quote
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
best bit(s) to do electircal install rtoni Electrical 13 11-26-2007 08:24 AM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
Drill to mix thinset dbrew Tools 25 08-08-2007 10:48 AM
