The new microwave is going to cover the area of tile behind it. Before starting to make holes in the tile which is going to butcher up that area, why not just remove the tiles just around the mounting hole area.
If the tiles were glued with mastic to the original wall surface, this should be easy.
If you end up needing to drill through tile, here is a sample of a
CERAMIC HOLE SAW SET:
http://doitbest.com/Hole+Saws-Vermon...sku-301124.dib
What kinds of bits should I have in my garage? Any set recommendations?
Here is a 37 piece set from Hitachi that includes masonry bits and a whole range of driver bits in one compact set where every bit has its own home where hopefully it will be returned to after each use.
http://www.tylertool.com/hitachi114....rce=googlebase
I have lot's of drills, Drill sets, Electrician's drills, Hole saw sets, bell hanger drills, Masonry sets, and spline bits but 90% of the time, the Hitachi Set will do the job + the drivers are in the same box.
