Which Drill Bit For Plasterboard? - Tools - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 04:26 PM   #1
Which drill bit for plasterboard?
some of the walls in my house are made of plasterboard, think you guys refer to it as drywall over there? Anyway what drill bit would be best for it, I thought it would be masonary but I have had people tell me that a wood bit is mroe accurate but I am worried I might ruin the woodbit by using it. What do you guys think? Thanks
Homervanderjazz is offline   Reply With Quote
Old 03-01-2012, 05:23 PM   #2
Civil Engineer
Rewards Points: 4,792
A wood bit such as a spade bit gets eaten up very quickly by gypboard (wallboard). I use titanium nitride coated steel bits, they last pretty well.
Old 03-01-2012, 05:26 PM   #3
Rewards Points: 13,764
How many holes are you talking about? If just a few any drill bit will do it fine.
Old 03-01-2012, 06:55 PM   #4
re
well it is only for a shelf so 4 to 6 holes,
"I use titanium nitride coated steel bits"
Dan- is this a type of wood drill bit?
Old 03-01-2012, 08:33 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,218
if its only 4 - 6 holes a standard wood bit will work just fine.. if your talking about dozens of holes or more id look into a more durable bit
if you burn up the one bit from a set you can buy individual bits in speficic sizes to replace the dead bit
woodworkbykirk is online now   Reply With Quote
Old 03-01-2012, 08:44 PM   #6
Rewards Points: 6,652
A nail usually works better and quicker than a drill bit.
Old 03-02-2012, 10:06 PM   #7
and they don't get the insulation all tangled up on it
sevenlol is offline   Reply With Quote
Old 03-02-2012, 10:52 PM   #8
How heavy is this shelve?
Far better to hit the studs and use a longer screw.
If I have to insert a screw into just drywall I've had good luck with these.
http://www.homedepot.com/webapp/wcs/...=cii%5f5784816
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 07:00 PM
hammer drill vs. rotory hammer, my results. forresth Tools 3 09-15-2011 09:08 PM
7" Tapcon drill bit wobbles?? ARuby Tools 6 08-17-2011 09:53 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 12:01 PM
