Dremel Trio - Tools - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 05:18 AM   #1
Rewards Points: 77
Dremel Trio
Anybody have one?
I just bought to use as a "roto-zip" and cut through some OSB, not sure that I am impressed. It does to the job, just not very well. I think I may be better buying a jig saw, and cutting 4 holes and going corner to corner to cut out an outlet box.
mikeylikesit580 is offline   Reply With Quote
Old 10-27-2011, 05:49 AM   #2
DIY staff
Rewards Points: 7,174
Roto Zips only work well in drywall----They are slow and eat up bits--and do a poor job--on any other material that I have attempted to cut.
Old 10-27-2011, 06:25 AM   #3
Rewards Points: 77
Thanks Mike,
Looks like im going to go buy a jig saw
Old 10-27-2011, 06:31 AM   #4
DIY staff
Sometimes the old way is still the best way.
If the price is not to high look at the 'orbital' cut versions--they cut faster and don't seem to burn up the blades as quickly.
I don't own one myself----my ancient Sears one refuses to die and I don't use a jig saw very often.
Old 10-27-2011, 07:19 AM   #5
kwikfishron's Avatar
Rewards Points: 378
Much nicer when cutting curves too.
That one can sure be a tough sell here sometimes.
kwikfishron is online now   Reply With Quote
Old 10-27-2011, 12:31 PM   #6
Rewards Points: 78
In your original post you mentioned "an outlet box". Nothing beats the feeling of taking home a brand new power tool, so certainly not trying to sway you one way or the other, but if you are literally concerned with "an outlet box", you could get by for as little as about $2, I imagine anyway, for a one-end handle for a hack saw blade, or you go deluxe and buy a keyhole saw, I imagine for less than $20. Otherwise, I agree with a jig saw over the Trio. Like Mike, my jig saw is old, or at least broken in, probably around 50 years, and I don't use it a lot, but often enough that I would have a hard time not having one.
Old 10-27-2011, 07:04 PM   #7
DIY staff
My tools aren't old---they are well trained and highly experienced!!!
Old 10-27-2011, 07:50 PM   #8
Rewards Points: 78
I'd like to think that, but I must be doing a poor job training some of them, because they still make dumb mistakes some days! And take a square as an example; I don't have many that are newer than 20 or so years, but they get more like an old mule every day. Some days the 16's don't even bother to show up, unless I take my glasses off, wrinkle my nose, and scowl at them.
Old 11-06-2011, 12:20 PM   #9
In a little over my head
Rewards Points: 706
BTW, you don't need to drill holes at the corners. Practice plunge cutting on some scrap. That one technique doubles the utility of any power saw, circular, recip or jig.
ratherbefishing is offline   Reply With Quote
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 04:37 AM
Dremel twist-on chuck got caked and won't release amakarevic Tools 1 01-10-2011 11:34 PM
dremel seawiz Tools 8 03-09-2010 06:01 PM
Killed my Dremel Clutchcargo Tools 4 03-16-2008 08:40 AM
trio palm Floorwizard Off Topic 15 05-26-2007 06:56 PM
