Dremel Tool Attachments Too Short - Tools - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 07:22 PM   #1
Burl woodworker
I am looking for attachments that have a longer-than-standard shaft. Most of Dremel's are about 1" to 1 1/2" long. I want to find some closer to 2" or 2 1/2" long. Does anyone know of a company that makes specialty tolls for Dremel tools?
Burl Man is offline   Reply With Quote
Old 10-02-2015, 11:09 AM   #2
blksith0's Avatar
Rewards Points: 12
I would also like something like this that extends the range of the bit so that the body of the dremel doesn't interfere with what you're cutting.
blksith0 is offline   Reply With Quote
Old 10-02-2015, 11:59 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
The only thing I know is the Wecheer Rotary tool:
http://www.woodcraft.com/Product/147...J7gRoCDoLw_wcB
It won't extend the bit but it should allow you to get into the work.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-02-2015, 08:13 PM   #4
Rewards Points: 13,288
Never seen one, likely because at that speed the shaft would bend or break off.
What is it your trying to do with it?
Yodaman (10-02-2015)
Old 10-02-2015, 08:51 PM   #5
Property Mgt/Maint
Rewards Points: 736
if you can go to a tool with a 1/4'' shank you can find some longer tools,
Roto-zip or small router use 1/4
Yodaman is online now   Reply With Quote
Old 10-03-2015, 06:42 AM   #6
Rewards Points: 489
Have you checked industrial suppliers like MSC?
MushCreek is offline   Reply With Quote
Tags
attachments , dremel
Short Circuit but Breaker does not trip vino82 Electrical 6 01-29-2010 01:54 PM
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 01:41 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 01:34 AM
