Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-22-2010, 10:27 AM   #1
dremel
I'm looking to buy a new dremel for some computer mods I'm planning on making. I know computer mods aren't really home improvement talk but I know dremels are tool talk. I have a black and decker one right now, its pretty solid but I'm looking for something with some more power and more attachments. Any help would be appreciated.
seawiz is offline   Reply With Quote
Old 02-22-2010, 12:06 PM   #2
dremel
What do you need to do, it would be much easier to purchase the parts you need instead of buying a whole new tool. If you describe the mods you need to make to the case / computer we could help more with what to purchase.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
Old 02-22-2010, 01:30 PM   #3
Master General ReEngineer
Bondo's Avatar
dremel
Ayuh,... Depending on just How Much more power you're lookin' for,..
You might want to step up to a 1/4" corded rotary tool... Dewalt makes a nice 1... or Roto-zip...
Old 02-22-2010, 02:06 PM   #4
dremel
Its really just for cutting computer cases and such. I probably won't be using it for any construction work. The problem is the dremel I have now has a very hard time cutting through aluminum, don't know if there are any out there that can handle it or if I need to upgrade to a more powerful tool all together. So, I guess that answers the power question as well.
Old 02-22-2010, 03:08 PM   #5
Bondo's Avatar
dremel
Ayuh,... Aluminum is a bytch to cut, because it melts,+ loads up the cutting tool....
Rub the cutting edge of the tool on some beeswax before,+ during your cut...
Keeping the base metal Cold also helps... Keeping it damp/ wet helps with cooling it...
Old 02-22-2010, 06:16 PM   #6
Tool Geek
PaliBob's Avatar
dremel
Originally Posted by seawiz View Post
.....but I know dremels are tool talk......
wiz,You came to the right place
.......I'm looking for something with some more power and more attachments......
I bought a Dremel 4000 (the 400 series had a lot of problems) it has more power and convenience than in my still working 300 series motor. I bought it with the optional keyless chuck so I don't have to fiddle with that little wrench. I also prefer the corded tool versus the Li-Ion Dremels because of the corded tools higher power
http://www.amazon.com/Dremel-4000-2-...6872430&sr=1-3
There are a lot of trick new accessories:
I like the new tool less EZ Lock cutting wheels.
http://www.amazon.com/Dremel-EZ406-C...6872008&sr=8-1
I used it on a old Abus hardened steel padlock (I lost the key)
It took 40 seconds to cut through with NO visible wear on the cutting wheel.
There is also a special wheel for cutting Plastic
http://www.amazon.com/Dremel-EZ476-2...6874404&sr=8-1
For faster cutting in plastic and also enable straight line cuts with the aid of an external guide rail, here is a Mini Saw Attachment:
http://www.amazon.com/Dremel-670-Min...6874661&sr=1-3
Used with the Mini Saw Blade, but NOT for metal:
http://www.amazon.com/Dremel-546-01-...6874791&sr=1-4
For making circular holes in plastic cases regular hole saws can't be beat, but for irregular shaped holes, High Speed Cutters work good in plastic:
http://www.dremel-direct.com/acatalo...d_Cutters.html
I used two of the cutters to make the irregular hole for the epoxied in Test Plug on the attached pic.
& Stay Safe
.....Bob Lavery
Old 03-08-2010, 03:54 PM   #7
remodeling pro
dremel
Dremels are a handy little tool, but they are still more a hobby tool than "work" tool. As suggested, sounds like you really need to go with a true rotary tool also known as a "die grinder", from their design purpose of being a detail working tool for the die and tool making industry.
troubleseeker is offline   Reply With Quote
Old 03-09-2010, 11:37 AM   #8
dremel
Oh, I dont know about "hobby" tool. I think each has it's own place. I find that I use a dremel more than my die grinder. If I need to cut a bolt or grind something small down I reach for a dremel. If I need to sharpen my shovel or clean up some rust, I grab a die grinder. Could each do the job of the other in a pinch, yeah.
For cutting a hole in a computer case, I would go with the dremel.
Old 03-09-2010, 07:01 PM   #9
Tool Geek
PaliBob's Avatar
Smile
dremel
Originally Posted by JCAHILL4 View Post
Oh, I don't know about "hobby" tool.....
I lost the key for this Lock. It took exactly 40 seconds for a EZ Lock cutter wheel to cut through the shank using a 20 year old Dremel model 395.
After the cut there was no apparent wear on the EZ-Lock cutting wheel.
http://www.amazon.com/gp/product/B00...d_i=B00004UDI9
The new 4000 series Dremels have a more powerful motor.
http://www.amazon.com/Dremel-4000-2-...8179027&sr=1-1
& Stay Safe
.....Bob Lavery
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 05:37 AM
Dremel Tool Attachments Too Short Burl Man Tools 0 01-29-2010 07:22 PM
dremel rotary accessories peter2008 Tools 2 09-11-2008 12:32 AM
Killed my Dremel Clutchcargo Tools 4 03-16-2008 09:40 AM
Dremel jte1130 Tools 10 02-10-2008 11:04 PM
