Dremel 4000 Vs 4200 - Tools - DIY Chatroom Home Improvement Forum
Old 04-20-2014, 07:37 PM   #1
Dave88LX's Avatar
Rewards Points: 564
Dremel 4000 vs 4200
In the market for a rotary tool. Dremel is what comes to mind. If I should look at something else, let me know. I don't mind spending the $100 on a 4000 or $130 on a 4200 though.
Sold at Amazon/Big Orange/Blue Box.
http://www.lowes.com/pd_406991-353-4...mel&facetInfo=
http://www.lowes.com/pd_407078-353-4...mel&facetInfo=
Both Amazon and box store reviews seem to favor more highly towards the 4000 over the 4200. I know the 4200 is newer.
Any input or reasoning the 4200 may not be as good? Looking beyond the EZ-Change system (unless that is a flaw).
Dave88LX is offline   Reply With Quote
Old 04-20-2014, 07:49 PM   #2
Rewards Points: 12,858
What do you plan on using it for?
Pretty light duty tool for any real work.
Only time I've used mine is to reslot a flat head screw head, and open up a latch plate that was a little to low.
Gymschu (04-20-2014)
Old 04-20-2014, 08:05 PM   #3
Dave88LX's Avatar
Rewards Points: 564
Pretty much light-duty stuff. Initial projects are to remove a couple brackets (chain guard) on my daughter's bike and a little shaping on some wooden tool cut-outs my wife wants hung up on my son's walls. I have a die grinder (in a box somewhere) for heavier duty stuff.
I know I'll have plenty of uses though, I used my old one quite a bit for non-heavy-duty stuff.
Were you suggesting something else?
Old 04-20-2014, 09:56 PM   #4
firehawkmph's Avatar
Rewards Points: 1,800
I've got the 4000, and I will say it does the work it is designed for very well. I use it mainly to accent my woodturning. The other day I sliced a bearing race in two that I couldn't drive out in the normal fashion. I also bought the flexible shaft for it and that's now it stays hooked up all the time. The smaller hand piece on the flex shaft is much easier to hold when doing the finer work. There are a lot of different types of bits and cutters that will fit it. Helps to have a good variety on hand, along with spares of the ones that consume themselves as you are using them.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 04-20-2014, 10:05 PM   #5
Dave88LX's Avatar
Rewards Points: 564
I decided on the 4000. I saw too many negative posts about the brushes and on/off switch on the 4200.
Can I cut wood with the Dremel Metal cutting circle? tmptplayer Tools 16 08-07-2015 09:53 AM
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 12:27 PM
Rotary Cutting tools (Dremel etc) ElectricMD Tools 5 02-15-2012 06:35 PM
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 05:37 AM
WW Recommending 4000 instead of 6000?? Hmmm lucky8926 General DIY Discussions 10 03-10-2009 08:43 PM
