Dremel - Tools - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 11:26 PM   #1
Rewards Points: 115
Dremel
What are the pros and cons of Dremel Wired Vs Wireless. Any drawbacks of wireless power wise?
texasman21 is offline   Reply With Quote
Old 04-13-2013, 11:32 PM   #2
Rewards Points: 13,300
What do you plan on doing with it?
Cost of replacement batterys and a shorter running time come to mind.
Old 04-13-2013, 11:57 PM   #3
Rewards Points: 115
Nothing heavy duty just around the house chores. Cutting small holes, Sanding, Grinding. Whats the run time mainly on them if you know.
Old 04-14-2013, 12:03 AM   #4
I have a corded one so I can not help you out on the run times.
Old 04-14-2013, 12:41 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
I would go corded.....
A Dremel is one of those tools that you don't use very much....I use mine maybe twice a year....hence, if it had a battery....the battery wouldn't last long. When you get ready to use it, you will most likely have to charge the battery....
Rechargeable batteries need to be used and cycled regularly to give the the longest life....sitting idle for 6 months at a time kills them quick.
If your going to use it several times a week....and it needs to be portable...then go battery.,...
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
joecaption (04-14-2013), r0ckstarr (04-14-2013)
Old 04-14-2013, 12:47 AM   #6
Rewards Points: 115
If i went cordless would i get the same power as the corded one. That's my main concern. The one im looking at is the Dremel 8220. Also whats the main difference between the 1/28 or 2/28 models.
Old 04-14-2013, 08:01 AM   #7
Rewards Points: 5,974
I would consider a multi tool for around the house it seems it would have a lot more uses.
Old 04-14-2013, 10:43 AM   #8
Rewards Points: 222
corded is most reliable and usually more powerfull. but cordless can be real handy at times. dremel = corded.
Fix'n it is offline   Reply With Quote
Old 04-15-2013, 11:45 PM   #9
mack65's Avatar
I've had my Dremel for so many years now I can't remember getting it,
It's one of the most useful tools
And not once can I remember thinking I wish I had a cordless Dremel
Go for a corded one
mack65 is offline   Reply With Quote
Old 04-24-2013, 04:03 PM   #10
I've had both. The cordless one was next to worthless with a short run time and inferior speed. I now have only my corded and will never buy a cordless one again.
Catdaddyxx is offline   Reply With Quote
The Following User Says Thank You to Catdaddyxx For This Useful Post:
PaliBob (04-24-2013)
Use Rockwell blades on Dremel Multimax miamicuse Tools 0 03-09-2013 12:27 PM
Rotary Cutting tools (Dremel etc) ElectricMD Tools 5 02-15-2012 06:35 PM
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 05:37 AM
Killed my Dremel Clutchcargo Tools 4 03-16-2008 09:40 AM
Dremel jte1130 Tools 10 02-10-2008 11:04 PM
