-   Tools (http://www.diychatroom.com/f29/)
-   -   Dremel (http://www.diychatroom.com/f29/dremel-177084/)
texasman21 04-13-2013 11:26 PM
Dremel
What are the pros and cons of Dremel Wired Vs Wireless. Any drawbacks of wireless power wise?
joecaption 04-13-2013 11:32 PM
What do you plan on doing with it?
Cost of replacement batterys and a shorter running time come to mind.
texasman21 04-13-2013 11:57 PM
Nothing heavy duty just around the house chores. Cutting small holes, Sanding, Grinding. Whats the run time mainly on them if you know.
joecaption 04-14-2013 12:03 AM
I have a corded one so I can not help you out on the run times.
ddawg16 04-14-2013 12:41 AM
I would go corded.....
A Dremel is one of those tools that you don't use very much....I use mine maybe twice a year....hence, if it had a battery....the battery wouldn't last long. When you get ready to use it, you will most likely have to charge the battery....
Rechargeable batteries need to be used and cycled regularly to give the the longest life....sitting idle for 6 months at a time kills them quick.
If your going to use it several times a week....and it needs to be portable...then go battery.,...
texasman21 04-14-2013 12:47 AM
If i went cordless would i get the same power as the corded one. That's my main concern. The one im looking at is the Dremel 8220. Also whats the main difference between the 1/28 or 2/28 models.
ToolSeeker 04-14-2013 08:01 AM
I would consider a multi tool for around the house it seems it would have a lot more uses.
Fix'n it 04-14-2013 10:43 AM
corded is most reliable and usually more powerfull. but cordless can be real handy at times. dremel = corded.
mack65 04-15-2013 11:45 PM
I've had my Dremel for so many years now I can't remember getting it,
It's one of the most useful tools
And not once can I remember thinking I wish I had a cordless Dremel
Go for a corded one
Catdaddyxx 04-24-2013 04:03 PM
I've had both. The cordless one was next to worthless with a short run time and inferior speed. I now have only my corded and will never buy a cordless one again.
