Dremel - Tools - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 08:18 AM   #1
natwlsn's Avatar
Dremel
What are some of the small unique ways you've found your dremmel to come in handy?
natwlsn is offline   Reply With Quote
Old 12-22-2011, 08:35 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
sharpening my chainsaw
tcleve4911 is offline   Reply With Quote
Old 12-22-2011, 09:14 AM   #3
Rewards Points: 13,228
Opening up the rectangluer hole in a strike plate on a door jam.
Cutting up the coping saw cut when doing molding.
Making a new slot then a screw head rounds off.
Cutting off a stray nail shank that pops through the jam on a door when installing casing.
Removing rust or corrosion on small objects.
Gymschu (12-22-2011)
Old 12-23-2011, 07:42 AM   #4
natwlsn's Avatar
I like the idea of using it for a new slot on a screw! Very useful!
Thanks for responding, guys!
Old 12-23-2011, 07:54 AM   #5
I use it to repair woodpecker damage to my house siding. I make round plugs, and use the dremel (with sanding drum) to make fine adjustments to hole size so that plug fits nicely.
+1 on the chainsaw, door strike, and screw slots.
oberkc is offline   Reply With Quote
Old 12-23-2011, 11:40 AM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I've used the little sanding drums to trim my dogs nails.
Old 12-28-2011, 07:24 PM   #7
Rewards Points: 87
My wife uses the rechargable one for her nails.
myowneq is offline   Reply With Quote
Dremel Tool Attachments Too Short Burl Man Tools 5 10-03-2015 06:42 AM
RotoZip vs. Dremel 400 amakarevic Tools 6 03-05-2011 05:37 AM
dremel rotary accessories peter2008 Tools 2 09-11-2008 12:32 AM
Killed my Dremel Clutchcargo Tools 4 03-16-2008 09:40 AM
Dremel jte1130 Tools 10 02-10-2008 11:04 PM
