Door Bottom Crooked (saber Saw Usage) - Tools - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 07:28 AM   #1
Rewards Points: 1,512
Door Bottom Crooked (saber saw usage)
When I use my saber saw to cut a thin strip off of a door bottom or piece of plywood or even cut a 2x4, the cut is rarely square. In the case of the door, "one side is higher".
Is this the nature of saber saws, or am I not doing it right such as trying to saw too fast?
Old 11-16-2010, 07:41 AM   #2
DIY staff
Rewards Points: 7,174
That's the nature of the tool---The blades are thin and flexible---they will be bent as they cut by a sap line or glue line--
Also if the blade is duller on on side it will bend and cut crooked.
Old 11-16-2010, 09:54 AM   #3
I would gor further by saying that cutting crooked (curved) lines is the purpose of a saber saw.
This is the wrong tool for this job. I would use a circular saw and straight edge. Choose the blade wisely to minimize tearout along cut line.
If you need to straighten an existing edge, a router/straight bit combo and straight edge are a good choice.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
oh'mike (11-16-2010)
Old 11-16-2010, 10:28 AM   #4
Rewards Points: 104
Exactly!
Also, particularly when cutting interior (hollow doors), I lay a piece of masking tape down before cutting, to help eliminate chipping.
I generally restict the sabre saw to thinner pieces, but when cutting thicker stock, I stay off of the line, to allow for the blade angle, and finish to the line with a rasp and/or sander.
Old 11-16-2010, 12:51 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
Another thing with the saber saw, sometimes we tend to try to stay on the line by pushing the saw side ways even without really realizing it. When we do this the blade will be forced to cut unsquare also.
One thing I always did to keep a door from splintering when cutting was to use a straight edge and using a knife cut across the door or score the surface. When cutting keep the saw on the off fall side of the scored line.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-16-2010, 01:02 PM   #6
Enough is Enough
H. A. S.'s Avatar
Sabre saws are like that, but this is also caused by using too much force while cutting. Take your time and you'll get a straighter cut.
H. A. S. is offline   Reply With Quote
Old 11-18-2010, 07:12 AM   #7
Rewards Points: 256
Adjust to make sure the blade is 90deg.
Put a new blad in don't force it.
You certainly can cut a strait line, but it's not the best tool for the job.
I would use a circ saw or handsaw.
michaelcherr is offline   Reply With Quote
Old 12-05-2010, 09:55 PM   #8
Disabling any orbital action your tool may have will help slow you down and improve cut quality and straightness.
JH
Hohn is offline   Reply With Quote
Old 12-06-2010, 10:22 PM   #9
Rewards Points: 5,336
Wrong tool for the job. A circular saw with a clamped straight edge or a belt sander for slivers.
Ron
Old 12-06-2010, 10:38 PM   #10
Civil Engineer
Rewards Points: 4,772
I use a router with a 3/4 inch diameter, 3-1/2 inch long carbide tipped straight bit to cut doors. When used with a fence, it makes a perfectly straight cut with minimal chipout, especially if you make multiple passes so you don't cut more than 1/2 inch with any one pass on hollow core, or 1/4 inch deep on solid core doors. I find the router gives a much better edge than carbide tipped table saw blades.
Closet door dilemma in a 1940's crooked house? glamgirrl Remodeling 8 02-24-2010 12:57 PM
cutting laminate with a saber saw? darsunt Flooring 6 02-22-2008 07:42 AM
saber saw limitations? darsunt Carpentry 4 02-21-2008 09:15 AM
