Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-15-2013, 06:03 AM   #1
Does the average DYI mechanic need sockets/wrenches bigger than 1"/25mm?
I have sockets/wrenches to 1 inch and 25mm. I will be using 24mm socket to remove upper control arm bushings. The arms themselves are bolted to the frame w/ 22mm bolts on my dakota. Except for axle work I think I'm good to go.Is there a need to purchase the craftsman 1-1 1/2 or 26-30 something mm socket sets?
toolaholic is offline   Reply With Quote
Old 02-15-2013, 06:05 AM   #2
Average dyi LOL
Old 02-15-2013, 06:31 AM   #3
Super Moderator
I fixed that typo for you---It's rare to need the big ones---but there is no substitute when you do need them---
I've got some large sizes--they don't see a lot of action---but they do get used every once and a while----
toolaholic (02-15-2013)
Old 02-15-2013, 07:13 AM   #4
Thanks oh mike! I even get to use my gearwrench 22mm wrench to turn the lisle upper shock bolt remover. I have the sae and standard large ratcheting wrench sets. This is the first time I get to use a metric "large" . I use the 1" from the sae set on k&n oil filters.
Old 02-15-2013, 07:17 AM   #5
I have a lowes practically on my backyard. They have sockets into the 30s metric. If I ever need one I think they start at 5.97. If you guys had some applications for big sockets; I'd buy the craftsman big sets and save $$$ per socket.
Old 02-15-2013, 07:40 AM   #6
Super Moderator
I did some millwright work some years back----the boss had some coffee cup sized sockets----My biggest are 1 1/2" or so----that's plenty big enough for keeping my tools and machines running----
Old 02-15-2013, 10:06 AM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,.... I've been a Mechanic for 'bout 40 years now, 'n have sockets, 'n wrenches from 1/4" to 4"s or bigger...
For a Diy'er mechanic, the standard Craftsman set that sells for 'bout $200. is Plenty of wrenches for Most work...
The Following User Says Thank You to Bondo For This Useful Post:
Old 02-15-2013, 10:18 AM   #8
Pro Flooring Installer
rusty baker's Avatar
I was a Toyota mechanic in the early 70's. Those tools are most of what I need. I have needed to buy a couple bigger sockets thru the years, tho. You can buy a lot of odds and ends at yard sales.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 02-16-2013, 01:16 AM   #9
Out of all the service departments my wife and I have dealt with; we like the Toyota one the best.
Old 02-16-2013, 11:50 AM   #10
World's Tallest Midget
Mort's Avatar
The Craftsman set that is around $200 (but always goes on sale) is the one I'm going to get when the tax fairy comes, and it goes up to 1 5/8 and 32mm I think. You'd be surprised what those bigger wrenches do, the carb inlet on my old S-15 pickup needed one that was bigger than an inch.
I would, however, save my money on the huge sets that go up to 2 1/2, unless you plan on working on train cars. And that's coming from a dude that does everything on my vehicles.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
toolaholic (02-16-2013)
Old 02-16-2013, 03:21 PM   #11
Bigplanz's Avatar
This largest socket I've ever needed was 15 mm. I have larger ones but have never needed them. Get the best quality you can. The reason? Cheap sockets will fall off the ratchet or extension bar and fall into the dark engine compartment, thus making you sad.
Bigplanz is offline   Reply With Quote
The Following 2 Users Say Thank You to Bigplanz For This Useful Post:
oh'mike (02-16-2013), toolaholic (02-16-2013)
Old 02-16-2013, 04:37 PM   #12
I'm going to use a 22 to remove upper control arm bolts and 24 to remove nut and washer from upper control arm bushings.
Old 02-16-2013, 04:58 PM   #13
Bigplanz's Avatar
I have those in an impact socket set. Never used them. Have 'em if I need 'em though.
Old 02-16-2013, 08:16 PM   #14
Missouri Bound's Avatar
Apparently he's stopping here first, to get your money.
Do you want it your way or the right way?
Old 02-18-2013, 05:09 PM   #15
I have a 36 mm socket I bought to take a big nut off of an old VW transaxle. I had my 200 lbs on a 6' pipe to break that sucker loose! I only buy big sockets as I need 'em.
MushCreek is offline   Reply With Quote
The Following 3 Users Say Thank You to MushCreek For This Useful Post:
Dave88LX (03-05-2013), oh'mike (02-18-2013), toolaholic (02-19-2013)
