-   Tools (http://www.diychatroom.com/f29/)
-   -   Does the average DYI mechanic need sockets/wrenches bigger than 1"/25mm? (http://www.diychatroom.com/f29/does-average-dyi-mechanic-need-sockets-wrenches-bigger-than-1-25mm-171981/)
toolaholic 02-15-2013 06:03 AM
I have sockets/wrenches to 1 inch and 25mm. I will be using 24mm socket to remove upper control arm bushings. The arms themselves are bolted to the frame w/ 22mm bolts on my dakota. Except for axle work I think I'm good to go.Is there a need to purchase the craftsman 1-1 1/2 or 26-30 something mm socket sets?
toolaholic 02-15-2013 06:05 AM
Average dyi LOL
oh'mike 02-15-2013 06:31 AM
I fixed that typo for you---It's rare to need the big ones---but there is no substitute when you do need them---
I've got some large sizes--they don't see a lot of action---but they do get used every once and a while----
toolaholic 02-15-2013 07:13 AM
Thanks oh mike! I even get to use my gearwrench 22mm wrench to turn the lisle upper shock bolt remover. I have the sae and standard large ratcheting wrench sets. This is the first time I get to use a metric "large" . I use the 1" from the sae set on k&n oil filters.
toolaholic 02-15-2013 07:17 AM
I have a lowes practically on my backyard. They have sockets into the 30s metric. If I ever need one I think they start at 5.97. If you guys had some applications for big sockets; I'd buy the craftsman big sets and save $$$ per socket.
oh'mike 02-15-2013 07:40 AM
I did some millwright work some years back----the boss had some coffee cup sized sockets----My biggest are 1 1/2" or so----that's plenty big enough for keeping my tools and machines running----
Bondo 02-15-2013 10:06 AM
Ayuh,.... I've been a Mechanic for 'bout 40 years now, 'n have sockets, 'n wrenches from 1/4" to 4"s or bigger...
For a Diy'er mechanic, the standard Craftsman set that sells for 'bout $200. is Plenty of wrenches for Most work...
rusty baker 02-15-2013 10:18 AM
I was a Toyota mechanic in the early 70's. Those tools are most of what I need. I have needed to buy a couple bigger sockets thru the years, tho. You can buy a lot of odds and ends at yard sales.
toolaholic 02-16-2013 01:16 AM
Out of all the service departments my wife and I have dealt with; we like the Toyota one the best.
Mort 02-16-2013 11:50 AM
The Craftsman set that is around $200 (but always goes on sale) is the one I'm going to get when the tax fairy comes, and it goes up to 1 5/8 and 32mm I think. You'd be surprised what those bigger wrenches do, the carb inlet on my old S-15 pickup needed one that was bigger than an inch.
I would, however, save my money on the huge sets that go up to 2 1/2, unless you plan on working on train cars. And that's coming from a dude that does everything on my vehicles.
Bigplanz 02-16-2013 03:21 PM
This largest socket I've ever needed was 15 mm. I have larger ones but have never needed them. Get the best quality you can. The reason? Cheap sockets will fall off the ratchet or extension bar and fall into the dark engine compartment, thus making you sad.
toolaholic 02-16-2013 04:37 PM
I'm going to use a 22 to remove upper control arm bolts and 24 to remove nut and washer from upper control arm bushings.
Bigplanz 02-16-2013 04:58 PM
I have those in an impact socket set. Never used them. Have 'em if I need 'em though.
Missouri Bound 02-16-2013 08:16 PM
:eek:Apparently he's stopping here first, to get your money.:laughing:
MushCreek 02-18-2013 05:09 PM
I have a 36 mm socket I bought to take a big nut off of an old VW transaxle. I had my 200 lbs on a 6' pipe to break that sucker loose! I only buy big sockets as I need 'em.
