Does Anyone Have Experience With This Air Compressor Kit? (Porter Cable) - Tools - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 05:48 AM   #1
The Moose is loose.
MooseWoodworks's Avatar
Does anyone have experience with this Air Compressor kit? (Porter Cable)
I've been thinking of picking this up for a few days now. The reviews on the Home Depot website are good, but I figured I would ask here as well. It seems like a good deal, but I am not completely sold on the ability of the unit to hold up over time.
http://www.homedepot.com/Featured-Pr...atalogId=10053
MooseWoodworks is offline   Reply With Quote
Old 12-27-2011, 06:56 AM   #2
just a tool guy
mickey cassiba's Avatar
The little oil free compressors are a hit or miss thing. Some will last for years, and some will belly up with relatively low hours. The newer PC nail guns, I cannot speak to. The only ones I've had any experience with are the brad nailers. In a commercial environment, they went down rather quickly. In a home use situation they could last for a long time.
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
The Following User Says Thank You to mickey cassiba For This Useful Post:
MooseWoodworks (12-27-2011)
Old 12-27-2011, 07:01 AM   #3
The Moose is loose.
That is what I was afraid of. Thanks for your input.
Old 12-27-2011, 08:20 AM   #4
Rewards Points: 13,748
Depends on what your going to use it for. For a home owner it's fine.
Never going to be able to keep up with a sandblaster, or paint gun. But for one gun at a time it's fine.
We tryed them for roofing and they would last a year then the piston and rings would be shot. But that's running two guns at a time and 8 hours a day.
Old 12-27-2011, 08:26 AM   #5
The Moose is loose.
That doesn't sound bad at all for what I would do with it. I would probably upgrade before the time came to replace the unit because of it dying if that were the case. What I am concerned about it buying it and using it for 3-4 projects and it crapping out just past the point where I could swap it out for another one or just past the warranty. It's very important to me to get stuff that have great warranties or that I know the quality is there. I'll pay extra for peace of mind.
Old 12-27-2011, 09:26 AM   #6
In a little over my head
Rewards Points: 706
I'm not a pro. DIY only. I have 3 PC nailers that have done everything I've asked. The framer's done an addition, several outbuildings, finished a basement. Brad and finish nailers work great.
I figure any oil-less compressor is not a lifetime tool. If you want long life, get a cast iron compressor with a oil sump. But for homeowner use, running a nailer, inflating tires, etc, I'm guessing that one will work well. If you want to use it for large CFM tools; sanders, grinders, buffers, sprayer, you'll be dissapointed.
If you're shopping at HD, there's a sticker on the tanks of the larger units that indicate what it will do.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Old 12-27-2011, 09:33 AM   #7
The Moose is loose.
Thank you. Yea, this unit will be used solely for nailing. Finish nailing specifically. I am getting into a little woodcraft/furniture making and that's all this will be for. As my needs expand, so will the tools I'll be using. My biggest concern with this unit is that I'll need to get 3-5 years out of it. I think it can do that with the load I'll be putting on it.
Old 12-27-2011, 09:52 AM   #8
home renovation expert
I had a 20G and it blew up in a h.o garage the moter exploded.leave it at depot
ridge-runner is offline   Reply With Quote
Old 12-27-2011, 09:54 AM   #9
The Moose is loose.
A 20 gallon Porter Cable? what happened exactly?
Old 12-27-2011, 11:00 AM   #10
bpm
Rewards Points: 29
I have an older version of that compressor. Mine came with the narrow crown stapler and brad nailer. I've had it about 6 years and it has been great. It has run a framing nailer and a roofing nailer with no problems. I've built a garage, a shed, reroofed my house and various other projects and it has held up great. These days it's mostly just running a finish nailer and pin nailer, and occassionaly inflating car tire or kids toys, but it's still alive and kicking. I didn't expect it to last as long as it has, but the price was right and it has more than met my expectations. I have a few friends with the same setup and have had good luck also.
bpm is offline   Reply With Quote
The Following User Says Thank You to bpm For This Useful Post:
Old 12-27-2011, 12:16 PM   #11
The Moose is loose.
Do you think it's safe to say that the guns will outlast the compressor?
Old 12-27-2011, 01:50 PM   #12
bpm
Rewards Points: 29
I can't really say. The compressor certainly has lasted longer than I expected. When I started using it to run some heavier duty guns, like a framing nailer and roofing nailer, I thought it would quit in no time. To my surprise, it's still going strong.
As for the guns that it came with, they don't get too much use and when they do, they don't get used too hard. It's all indoor use and I haven't dropped them (too much).
Old 12-27-2011, 10:24 PM   #13
I was doing a roof heard a bang. Climbed down the ladder. some steel cylnder inside was shattered. my gc (sub-contract) took it back and got a 8g bostitch and it worked good...and yeah a 20 G stand up
Old 12-28-2011, 05:32 AM   #14
The Moose is loose.
Wow. Lucky no one was near it I guess.
Old 12-28-2011, 10:53 AM   #15
Yeah. No kidding. :eek:
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
18 gage porter cable gun reststop Carpentry 5 09-17-2010 02:18 PM
Porter Cable 135psi compressor ski940 Tools 7 02-13-2008 08:27 PM
Porter Cable Reconditioned Tools Rayce Tools 6 01-07-2008 07:21 AM
Porter Cable FR350A Jams With Grip-Rite Fasteners BigJimmy Tools 4 11-11-2007 01:26 PM
