Does Anyone Have The DeWalt DC411? - Tools - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 04:59 PM   #1
Rewards Points: 154
Does anyone have the DeWalt DC411?
I have a couple questions regarding tightening the blade.
Thanks in advance.
llckll is offline   Reply With Quote
Old 02-11-2010, 08:16 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
ll,
I have one of those as part of a five piece kit. What do you need to know?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-11-2010, 08:57 PM   #3
Rewards Points: 154
Hi,
When I put the blade on and try to tighten it, the blade is still very loose and I can free spin the blade even when I think the clamping nut is tightened all the way. I cannot tighten it anymore while pressing the spindle lock. Also, which way should the face of the blade face?
I got this pic from the internet. Am I missing a clamp on the backside or something?
Thanks.
Old 02-11-2010, 08:59 PM   #4
Rewards Points: 154
Maybe something is in the way of the clamping nut thread preventing it from tightening anymore? Going to try and take a few pics and mess around with it some more.
Old 02-11-2010, 09:15 PM   #5
Rewards Points: 154
This is what I have:
Can't get any tighter and no matter what I try to do, the blade still spins like it's loose.
Any ideas?
Old 02-11-2010, 09:17 PM   #6
Rewards Points: 154
Maybe the donut hole is too big or it's the wrong blade? But I doubt it because this is the blade that it came with in my 6 piece toolkit as well.
Old 02-12-2010, 07:26 AM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,....You've got the wheel on upside-down,...
The way it sits in the picture, you should be lookin' at the cutting face, not the label...
Take everything off the spindle, then flip the bottom backer plate over,...
You have the offset of the backer plate,+ the jamnut both facing center,... That's fine for thicker wheels, like 1/4"...
But, when using the .045" wheel, the offsets are hitting each other...
Old 02-12-2010, 07:30 AM   #8
Rewards Points: 154
I tried flipping the blade but I get the same results. Loose blade.
Old 02-12-2010, 08:52 AM   #9
Rewards Points: 154
So are you saying that I should even flip the backing flange too and not just the blade?
Old 02-12-2010, 09:47 AM   #10
Love for Construction
<*(((><'s Avatar
What bondo is saying is that the spindle nut has a 'cone' (for lack of better word) that centers the mounting hole on the disc. The outside lock nut also has a cone that can center the disc as well. Well when you have both cones facing each other, they bottom out on each other. Meaning for this narrow of a disc you need to only have one 'cone' centering the disc and the lock nut 'cone' facing away from the disc so they don't bottom out on each other.
And the paper side of the disc should be facing towards the spindle, not out like you have in the pictures. I think you stated you realize this, but just wanted to make sure.
<*(((>< is offline   Reply With Quote
Old 02-12-2010, 09:54 AM   #11
Rewards Points: 154
Thank you all for the advice. So essentially, all I have to do is flip the spindle nut OR the lock nut so that both cones don't face each other. I'll try that when I get home. Can I flip both for greater grip to the blade?
On both nuts, it specifically says that this side must not face the wheel so therefore I was just doing what they told me to do.
Old 02-12-2010, 11:28 AM   #12
Bondo's Avatar
Ayuh,... Flip over Only the backer plate...
If you flip the Jam nut over, you can't use the spanner to remove it, the Holes won't be exposed...
Old 02-12-2010, 12:03 PM   #13
Rewards Points: 154
Gotcha. Thanks for your advice.
Old 02-12-2010, 06:52 PM   #14
Rewards Points: 154
worked like a charm.
Thanks.
Old 02-12-2010, 08:02 PM   #15
IIlck,
That nut is made to flip to allow for using the thin blades like you have in the pics, and also the thicker blades that are made to grind on metal instead of cutting it. Also you might want to try one of the flap style wheels for grinding. They come in different grits and are great for grinding and leaving a very smooth finish. I use it to sharpen my lawnmower blades. Available at hd and lowes for about 7.00 each.
Mike Hawkins
What is the difference between these two Dewalt? Crackers Tools 7 07-18-2009 11:08 PM
Ridgid 18v vs Dewalt 14.4v xrp vs el cheapo? scottrob Tools 28 05-08-2009 08:45 AM
dewalt 14.4v and 18v drill? revo33 Tools 26 04-18-2009 09:13 AM
Tools for Residential Building UpComingBuilder General DIY Discussions 5 12-12-2008 06:49 PM
DEWALT DRYWALL BIT AND QUIK DRIVE SCREWGUN ATTACHMENT !!! Good or Bad !!! KUIPORNG Remodeling 4 10-27-2006 07:26 AM
