Do Most Table Saws Come With Crosscut Sleds? - Tools - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 10:27 AM   #1
I just bought the rts10 ryobi table saw. I really knew nothing about woodworking or saws; I just needed a saw to build some shelves and other stuff. I quickly learned that you need a crosscut sled to make simple cuts like cross cuts easily and accurately. My question is, do most table saws come with premade crosscut sleds made by the manufacturer? If not, why don't they?
limitdiy is offline   Reply With Quote
Old 07-24-2012, 10:46 AM   #2
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Just Google'd it and your saw came up on Home Depot web page
http://www.homedepot.com/buy/tools-hardware-power-tools-saws-table-saws/ryobi-10-in-table-saw-with-stand-172775.html
As you call it "a crosscut sled" is pictured to the left of the blade, so I guess the answer is YES in your case
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-24-2012, 10:52 AM   #3
kwikfishron's Avatar
Rewards Points: 418
A table saw really shouldn't be your "go too" saw for crosscuts.
kwikfishron is offline   Reply With Quote
Old 07-24-2012, 07:37 PM   #4
Old School
Willie T's Avatar
I think you are confusing a "Miter Gauge" (a barely acceptable accessory) with a Crosscut Sled.... which is usualy about six times larger, and often runs in both grooves in the table.
And, no, table saws almost never come with crosscut sleds.
Willie T
The Following 4 Users Say Thank You to Willie T For This Useful Post:
jaydevries (07-24-2012), JulieMor (07-25-2012), mae-ling (07-24-2012), oh'mike (07-25-2012)
Old 07-24-2012, 08:14 PM   #5
If you Google 'table saw sled' you will find various options.
eg. http://www.bobsplans.com/FreeJigPlan...ableSawJig.htm
Old 07-24-2012, 08:20 PM   #6
Davejss's Avatar
Rewards Points: 746
Most, if not all, table saws come with a sliding mitre guage with which you can make some crosscuts. However, if you intend to do many large accurate crosscuts on your table saw you will have to build a sled. In the past I used my radial arm saw for most of my cross cutting work in the shop, and my handheld circular saw in the field. Sliding mitre saws are popular too.
Davejss is offline   Reply With Quote
Old 07-24-2012, 09:01 PM   #7
Rewards Points: 264
Biesemeyer used to make a sled, they are now owned by Delta and may not have it available any longer. And I think Delta made one years ago as well. I don't know of any saw that came with a sled, just the miter gauge, as mentioned already.
Some times they are referred to as boats.
We always make them. You can get kits and instructions from Bridge City, as well as other wood worker supply companies. And there are probably lots of plans available on the web.
7echo is offline   Reply With Quote
Old 07-24-2012, 10:49 PM   #8
Rewards Points: 2,212
Some actually have a sliding table.
mae-ling is offline   Reply With Quote
Old 07-24-2012, 11:07 PM   #9
Rewards Points: 272
those sliding tables are an accessory and very seldom come with the table saw. I would not recommend a sliding table for a ryobi saw. Not trying to put down that saw but .... it most definitely does not have the accuracy needed for a sliding table.
fixrite is offline   Reply With Quote
Old 07-24-2012, 11:30 PM   #10
Hey I didn't say it was good! Lol
Old 07-25-2012, 07:44 AM   #11
woody4249's Avatar
Rewards Points: 156
As an alternative to a "sliding table saw" like the "big boys" do, an accessory can be built pretty quickly. An example is below
http://woodgears.ca/delta_saw/sled.html
Having owned a cabinet shop for more years than I can mention, this is an easy way to cross cut trim, frames and narrow panels. This was a way of carrying out crosscutting in the field as our shop was equipped with CNC routers and "sliding table saws".
A WORD OF WARNING
Safety is the key here. Most injuries on table saws are caused by kickback.
All it takes is a split second and the item being cut can bind or jamb on the blade, particularly with long pieces. I have seen some scary moments when a board jams and throws the piece across the shop leaving the operator dazed.............and in one case hand-less.
Never but EVER use a fence in conjunction with a sled that extends past the blade. This is a disaster waiting to happen. If at all possible, use a key-way that is trapped in the slot on the saw. This will prevent the sled from jumping and possibly binding.
I have been very fortunate over the 46 years that I have been in this industry and learned by others misfortune.
Mike
The Following 2 Users Say Thank You to woody4249 For This Useful Post:
Evstarr (07-25-2012), VIPlumber (07-26-2012)
Old 07-25-2012, 09:24 AM   #12
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 90
You can go on the woodworking forum, listed at the bottom of this forum, and most likely find instructions on making a crosscut sled. No, most saws do not come with one. I had to build one for the $1100 cabinet grade saw in my shop, which did come with a Beisenmeyer fence. They are not accurate on a contractor grade saw, because the saw is not accurate. You can buy teflon slides for the groove in your table saw on line and they will help make a sled.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 07-25-2012, 09:32 AM   #13
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
The August 2012 issue of Fine Woodworking has an article titled, "Dead-square crosscut sled".
It's probably the easiest method I've seen for making one. They can really be a pain to build because everything has to be perfect. FWW has had many articles on how to build a crosscut sled. Most articles I've read from the pros leave me with the impression it is their opinion that a crosscut sled is the only way to go for accurate crosscuts, and it's safer than a miter gauge.
I have a slider on my Delta Contractor's table saw that is mounted in place of one of the table extensions on the left side of the saw. I use it for longer cuts like in plywood but most solid wood crosscuts I do on my sliding miter saw.
I find a table saw indispensable for ripping and cutting sheet goods but the miter saw is my go to for most crosscuts.
JulieMor is offline   Reply With Quote
The Following User Says Thank You to JulieMor For This Useful Post:
mae-ling (07-25-2012)
Old 07-26-2012, 07:15 PM   #14
my saw comes with a miter gauge, but its tiny and loose. its definitely not going to be that accurate.
the sleds I've seen people build on youtube look awesome. I just have to find and then cut some pieces of wood that will be small enough for my tiny miter rails on the table saw.
Standard or Sliding Mitre Saw? Or table saw? 7.62 Tools 18 05-07-2012 08:53 AM
10" table saw or compound mitre saw - which would you choose? whataboutj Tools 9 12-03-2011 03:13 PM
Table saws - public scourge!! Leah Frances Safety 28 10-21-2011 10:11 PM
Table saws Oddta General DIY Discussions 2 12-15-2010 06:39 AM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
