DIY Ladder, Bad Idea? - Tools - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 11:37 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
DIY ladder, bad idea?
It's time I buy a ladder, but did not realize the telescopic ones were that expensive. I don't have a truck so I can't buy a standard size one.
Then I realized, I can probably build one for under 50 bucks. I can fit a couple a 8' pieces of lumber in my car if I get it in at the right angle. I need maybe 10-12 feet or so of ladder to get on my roof at a comfortable angle. So why not put two 2x6 together with a couple bolts, then nail in some risers, and boom, a ladder. Seems simple to me and it would be rather solid.
Am I missing something, is this a really bad idea from a safety perspective? I can't see how anything could go wrong... But that can also turn into famous last words.
Old 05-07-2011, 06:30 AM   #2
General Contractor
joasis's Avatar
Craigslist, buy a decent used extension ladder, have it delivered, stay safe.
Home built ladders are typically heavy, awkward, and just are not as safe as the modern ladders we use.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 05-07-2011, 07:54 AM   #3
the Musigician
DangerMouse's Avatar
I've built 2 different custom ladders for odd jobs here. Not a big thing, and more than strong enough.
But yes, they're heavy and I wouldn't want to try to drag them all over town....
DM
Old 05-07-2011, 08:15 AM   #4
Rewards Points: 48
Not the best idea. Google "little giant ladder". I have no affiliation with them whatsoever, but a very versatile, compact ladder.
The Following User Says Thank You to DexterII For This Useful Post:
Willie T (05-07-2011)
Old 05-07-2011, 10:10 AM   #5
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I agree with DM. If you are using this for around the house, you'll be okay with a home made ladder, but it'll wear you out after dragging it around a few times.
The little giants are not that light either, but they do fold nicely and they are expensive.
WirelessG is offline   Reply With Quote
Old 05-07-2011, 10:11 AM   #6
Rewards Points: 372
There are 2 grades of Little Giant. The contractor grade is a very sturdy ladder. I have had 3 of us on mine, all pushing on a sprinkler head. Very stabil, but, it is heavy.
There is also a cheaper model.
fireguy is offline   Reply With Quote
Old 05-07-2011, 11:03 AM   #7
the Musigician
Here's a shot showing how I made mine 7 years ago.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Tom Struble (05-07-2011)
Old 05-07-2011, 12:47 PM   #8
Wire Chewer
Rewards Points: 54
I was thinking of notching it too, probably stronger that way. We don't have craigslist here but forgot to look at the local classifieds, I might try that before I build.
Old 05-07-2011, 03:02 PM   #9
WirelessG's Avatar
Rewards Points: 698
Are you out in the sticks somewhere? Craigslist covers several cities in Ontario. You can also try backpage.com and maybe even ebay. You'll be a lot happier with an aluminum or fiberglass one, but I guess a wooden one will let you fool with your new miter saw, which you would probably enjoy.
BTW - did you start your woodworking projects yet?
Old 05-07-2011, 03:22 PM   #10
Wire Chewer
Rewards Points: 54
No projects yet, I have to build my shop first, and that's low priority as I have to fix my weeping tiles first. Lot of things to do, not enough money!
The weeping tile project may end up leading towards a deck project though so that should be fun. I need to break up my current cement patio to dig.
Old 05-07-2011, 03:33 PM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you build a ladder, be sure to install some angle bracing to prevent it from racking.
Old 05-07-2011, 08:10 PM   #12
WirelessG's Avatar
Rewards Points: 698
When u get you're shop up and running, and if you're interested send me a pm and I can help you build some adirondack furniture. Its not really tough, but it does require some skill and its a good one to hone that skill. You'll need a bandsaw, table saw, router, and a drum sander. The chair is s modified version of norm Abrams design, while the table and footstool are my own. I make them out of cypress, which may be pricey in ur parts.....I don't know, but I thought you might be interested, so I mentioned it.
Old 05-07-2011, 08:34 PM   #13
Wire Chewer
Rewards Points: 54
Cool, yeah I'd like to try out furniture eventually. I'll start off with simple stuff like the ladder, and framing my basement, and move on from there. The issue is I don't have a truck, I'm hoping to get one in the next few years, then I can really do some bigger projects.
Old 05-08-2011, 11:42 AM   #14
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
I used a homemade ladder for years until I bought an aluminum. If built right, they ae fine.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
DangerMouse (05-08-2011)
12-18" Spacing Between Foundation And Paver Patio Bad Idea? ErikU19 Landscaping & Lawn Care 3 04-09-2011 09:20 AM
feedback on business idea Jack000 General DIY Discussions 18 12-20-2009 09:01 AM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 08:45 PM
300# versus 250# extension ladder Plasmech Tools 6 04-10-2008 04:53 PM
installing a ceiling ladder jerry1967 Carpentry 6 11-21-2006 12:18 AM
