Diagram Sears Craftsman Belt Sander - Tools - DIY Chatroom Home Improvement Forum
Old 04-27-2008, 11:51 AM   #1
Diagram Sears Craftsman Belt sander
I am looking for a Sears Craftsman 4" Belt Sander diagram model 315.11760. If anyone has this info, GREAT!!! I checked out Sears, most of the parts are obsolete. Thanks.
crosscharge is offline   Reply With Quote
Old 01-16-2010, 09:47 PM   #2
RE: Craftsman 315.11760
Just wondering - did anyone find the information requested? I have one of these old sanders and would love to have a copy of the manual and exploded part drawing, especially since the one on the Sears website is such a low quality scan.
Anyone else have this 4" belt sander with dust collection port on the side? If so please let us know.
Belt Sander is offline   Reply With Quote
Old 07-21-2011, 04:55 PM   #3
I know this is old but, I was searching for the same manual. I found a similar one here http://www.managemylife.com/mmh/lis_...M/L0805053.pdf
not too many parts available for either. Good luck.
PJM361 is offline   Reply With Quote
Old 07-21-2011, 06:58 PM   #4
Rewards Points: 5,336
Did you try Old Woodworking machines.com?
Ron
B. Franklin 1759
Old 07-23-2011, 04:37 AM   #5
I lent it to my brother and he gave it back not working. I opened it up and check to make sure there was power to the cord up to the trigger. Then thinking the trigger might be bad I bypassed it but, it still didn't work. Checked sears and there aren't many parts available anymore so i bought a new one.
Old 07-23-2011, 07:59 AM   #6
You need to lubricate the front cylinder on a regular basis. At 4 hours continuous use or 8 hours of intermittant use.
Ron
B. Franklin 1759
Old 07-23-2011, 11:58 PM   #7
The motor wasn't working & they don't sell the brush assembly anymore. My new Black & Decker died after 3 uses went back to Lowes & they let me return it.
Old 07-24-2011, 08:28 AM   #8
This is a long shot, but maybe the original manufacturer might still sell the parts. The first 3 digits of the model # indicates the manufacturer. In this case it referred to, Diehl Manufacturing Co. who was taken over by Ryobi in 1988.
Like I said, a long shot.
Ron
B. Franklin 1759
Old 07-24-2011, 05:50 PM   #9
Rewards Points: 468
when you bypassed the switch did you have voltage at the brushes ? They do sell the holder's and maybe the brushes come with them. A motor rebuilding service should have the brushes they are not special. You may not need the holder's ?? I would take it to a place that does repair they may know more than you at this point ?
del schisler is offline   Reply With Quote
Old 08-03-2011, 11:23 AM   #10
Rewards Points: 530
Not to derail, but I have a Mikita saw that I think needs brushings. At one time, you could spin the blade by hand, and it would run and cut fine. I did that few days ago because I was going to sell it in a yardsale. Got one or two reponses before it died completely.
The brushings show to be obsolete. Bought another, but wondering if an electrical supply/repair house might have brushings that would work.
Old 08-03-2011, 02:03 PM   #11
Rewards Points: 468
a good one should they can grind a bigger one to the size. bring the old one if you still have it. Did the old one have a spring that pushed the brush down on the arm. If so bring it also good luck as far ar the mikita they have brush's at $7 and some change. The brush's ware out due to the braking system. It take's the voltage and make's the armature try and go backward's. that is what stop's it. They pit real bad and it doesn't work turnung them aroung. I have tried and doesn't work. just get new ones
Old 08-03-2011, 02:13 PM   #12
Rewards Points: 530
Yeah, they are still complete, just worn down to the copper wire connection.
Old 08-03-2011, 09:09 PM   #13
I think it said Simpson and Sears on the side.
Old 08-03-2011, 10:30 PM   #14
My belt sander says "Craftsman". They never put the actual manufacturers name on a Craftsman tool.
I didn't realize Homer was in the business.
Ron
B. Franklin 1759
Old 08-03-2011, 10:49 PM   #15
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Simpsons-Sears Limited was the original name of Sears in Canada
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Sears belt drive 1/2 hp garage door opener pcampbell Appliances 4 03-27-2011 11:44 AM
Belt Sander? or other type... KUIPORNG Tools 7 04-18-2007 03:51 PM
Remove epoxy with ROS or belt sander? donnydoon Building & Construction 7 12-09-2006 10:33 AM
Belt sander repair longtimealaskan Tools 1 09-14-2006 10:17 AM
