Dewault DW272 Screwdriver - Tools - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 06:49 PM   #1
Rewards Points: 50
OK I am hoping this is user error. I am getting irratic screw head settings. I may get a few that are great with a slight dimple, then the head remains above the surface.
I keep adjusting the head to the right as stated in the direction, but nothing seems to matter.
Any assistance from someone who uses this particular screwdriver and or any idea as to what I may be doing wrong would be a ppreciated.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-17-2013, 08:30 PM   #2
Rewards Points: 13,250
Worn bit, not holding the tool perfectly at a right angle, hitting a knot or drilling into old wood.
digitalplumber (02-17-2013)
Old 02-17-2013, 10:14 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
none of joes above.. the problem is its dewalt.. their drywall guns are garbage. damn near impossible to get consistant screw depth out of them
if you want a quality drywall gun you have to go with milwaukee, makita or hilti. i dont even bother using a drywall gun anymore i simply use dimpler tips in a tip holder on my cordless impact.. it goes a little slower do to lower rpms but they set hte screws perfect every time
woodworkbykirk is offline   Reply With Quote
Old 02-17-2013, 10:17 PM   #4
Rewards Points: 50
Thanks beyond return date not much I can do now!
Old 02-17-2013, 10:28 PM   #5
I do them the same way.
I own two drywall guns, we used them once and there now for sale.
Old 02-28-2013, 05:38 PM   #6
Rewards Points: 50
Good news of sorts, I am off to the local Dewalt Factory Service Center to request a "statisfaction guarantee refund", tomorrow!
Went to their website to check on possibly returning this thing and saw that they have a 90 satisfaction guarantee, so long as the unit has not been abused.
So what do I buy now?
Old 02-28-2013, 05:58 PM   #7
I know there's going to be a bunch or differant opions on that question.
What's worked for me for many years is a Ryobi impact driver.
There less then 1/2 the price of most other brands, I can by 2, new batterys for less then the cost of just one of the other brands and never had one fail until many years later and hundreds of recharges.
I almost never use a drill any more.
An impact driver can drill holes, turn sockets, drive screws and has far more torque then a cordless drill.
I used to have all Dewalt tools long ago. I got tired of always having the batterys fail, bad switches, burned out brushes.
Some were bad right out of the box.
Do some of the other big name companys tools better, I'm sure they are. For a Diy The Ryobi impact driver is going to be fine.
Old 02-28-2013, 06:06 PM   #8
Rewards Points: 50
I was thinking about just going the impact driver way and using a dimpler!
Old 02-28-2013, 06:20 PM   #9
That's all I've used for many years. Works fine.
digitalplumber (02-28-2013)
Old 03-07-2013, 08:20 AM   #10
Rewards Points: 50
Well the 20 volt Dewalt impact driver came in. I guess mt effort coupled with an old dimpler and I am getting worse results. Head of screw soesnt recess.
Have new dimplers on the way. Old, old 2 x 4's and hardibacker.
Old 03-07-2013, 09:41 AM   #11
Try using galvinized roofing nails instead of screws.
Old 03-07-2013, 09:44 AM   #12
Rewards Points: 50
Let me ask you this, If I am going to use a Kerdi kit, does it really matter if my screws are not recessed?
Old 03-07-2013, 09:51 AM   #13
You would end up with a hump and it would be far harder to lay the tile.
I've had the same problum trying to get the screws all the way in, I can get it to work by using a counter sink but that slows the job down.
Started using nails instead and problum went away.
digitalplumber (03-07-2013)
Old 03-07-2013, 11:19 AM   #14
I bought the Milwaukee impact driver 12 volt. It is nice because it is so small and light, but I am wondering if I should have just went and bought an 18 volt impact driver. I like having a drill and impact driver together on a job.
paintdrying is offline   Reply With Quote
Old 03-07-2013, 09:20 PM   #15
Rewards Points: 50
Did you mean impact drill?
name for this kind of high-torque screwdriver? diy888 Tools 7 11-25-2012 10:57 PM
drywall screwdriver with nutsetter locking option amakarevic Tools 9 05-12-2012 08:43 AM
Searching for color coded screwdriver bits humberguy General DIY Discussions 9 03-28-2010 01:46 PM
Cordless screwdriver PirateKatz Tools 6 02-16-2009 04:01 PM
ryobi vs hitachi screwdriver larsonec Tools 1 06-26-2008 12:43 AM
