Dewalt Drill Problem - Tools - DIY Chatroom Home Improvement Forum
Old 02-09-2013, 11:08 AM   #1
dewalt drill problem
iv had a dewalt 230v corded drill for many years now and recently it made a bit of a funny noise and got quite warm so i left it, came back the next day and it would only operate at its highest speed and when i press the trigger just a bit for a little power theres nothing. iv had the drill apart today and the grease seal is quite worn so i shall be replacing that and the brushes are worn aswell.
has anyone had this problem and know a solution, i paid quite a lot for the drill so i dont fancy throwing it out and spending more money if its an easy fix
any help is appriciated.
Sedge123 is offline   Reply With Quote
Old 02-09-2013, 11:41 AM   #2
Rewards Points: 14,300
I've never had any luck with any Dewalt tools.
Brushes wear out and can stick in the holders in any drill.
If the commintator is dirty or shorted it can cause over heating and dead spots where the drill will not turn unless you hand turn the chuck.
No mention of model # so we can see what your talking about.
Also would be great if you went back and added your location to your profile.
May explain why it's 220 v and not 110 V.
PaliBob (02-10-2013)
Old 02-09-2013, 12:13 PM   #3
its a dewalt d21710-gb, i did put in the post it was a 230v, location doesnt really affect the drills useability
Old 02-09-2013, 12:24 PM   #4
It will if your in the US and your trying to run it on 110v outlet.
Old 02-09-2013, 03:56 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Sounds like a switch problem since the drill runs OK at high speed.
Drill Press Safety -- Big Problem ldjnx Tools 6 10-07-2011 03:03 PM
Determining correct drill key MRTIGRE General DIY Discussions 3 06-04-2009 01:58 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 01:46 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
