DeWalt Air Compressor Puzzle - Tools - DIY Chatroom Home Improvement Forum
Old 05-22-2015, 06:43 AM   #1
Rewards Points: 28
I recently purchased a used DeWalt air compressor model# D55146 Type 4. Right away I knew it needed new gauges and couplers. I replaced these and also installed a new regulator repair kit. Initially I tried to reduce the outgoing pressure but was unable to change it from 150#. So after installing the repair kit I had the same situation.
I called DeWalt's technical service department and was told that I need a new Manifold set which includes gauges, couplers, regulator and the manifold. The price about $135.00! The other components for the regulator are not available unless the manifold is purchased.
Anyone have suggestions? By the way DeWalt's customer service technicians are quite inept. I called them 3 times hoping I would get a legitimate hands-on technician but what I really got was a desk clerk that put me on hold so they could refer to their "frequently asked questions" section.
Hoping for an answer,
Jim
jrhutty is offline   Reply With Quote
Old 05-22-2015, 06:48 AM   #2
Rewards Points: 13,446
Any reason you can not just snap on a regulator to the female coupler?
Old 05-22-2015, 07:19 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... Unless yer tryin' to spray paint, just use it as it is,.....
If ya wanta spray paint, put in an in-line regulator,....
Old 05-22-2015, 08:40 AM   #4
Rewards Points: 28
I was wondering if this might be available. Perhaps I can find something at Harbor Freight. Thanks Joecaption.
Jim
Old 05-22-2015, 08:43 AM   #5
Rewards Points: 28
The primary reason for the compressor is for my nail guns - I am afraid it might blow some of their inards out. What do you think?
Jim
Old 05-22-2015, 08:46 AM   #6
Rewards Points: 980
When we know right away a product isn't worth a dam we should take it back and hope our second or third selection of a foreign product may be acceptable.
Old 05-22-2015, 09:34 AM   #7
Rewards Points: 850
aftermarket external regulator.
hotrod351 is offline   Reply With Quote
The Following User Says Thank You to hotrod351 For This Useful Post:
jrhutty (05-22-2015)
Old 05-22-2015, 01:42 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Even homer depot has the pressure regulators for around $20, just screw a female plug in one side and a male plug in the other and you are good to go.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 05-22-2015, 03:01 PM   #9
Rewards Points: 850
i have the same compressor, great compressor, have been using it for 20 + years. only thing that happened was a gauge went bad. this place ive ordered form before. you can take it apart to see if something is stuck inside, doesnt seem like you have anything to loose. as i remember they sold new for over $300.00. just read your post again, you installed a repair kit, well then something is wrong. maybe the spring is on the wrong side or something is messed up. you should be able to fix it, by the way, where did you find a repair kit for one of these.
Old 05-22-2015, 05:37 PM   #10
Rewards Points: 28
Thanks for the comments. I did find the kit at Toolpartspro but later found the same part at another site which was about $2 to $3 cheaper. I am very sure I installed it correctly but when I removed the old kit the diaphragm gasket was out of place - cocked sideways. Perhaps the new one has slipped sideways also.
Jim
Old 05-22-2015, 06:07 PM   #11
Rewards Points: 850
something to check.
Dewalt impact nut driver bits? koodawg Building & Construction 4 12-12-2010 09:55 AM
Bosch 4100 or Dewalt DW744X Table Saw? Goldglv Tools 10 03-17-2010 12:31 PM
Ridgid 18v vs Dewalt 14.4v xrp vs el cheapo? scottrob Tools 28 05-08-2009 08:45 AM
dewalt 14.4v and 18v drill? revo33 Tools 26 04-18-2009 09:13 AM
Tools for Residential Building UpComingBuilder General DIY Discussions 5 12-12-2008 06:49 PM
