Dewalt 235G Clogged Up - Tools - DIY Chatroom Home Improvement Forum
Old 01-15-2014, 04:40 PM   #1
Rewards Points: 894
Dewalt 235G clogged up
Hi;
I have a 5yr old DeWalt DW235G 1/2" drill. On several occasions, I used the drill in the attic to drill holes through floor joists for wiring. There is Rockwool insulation in this area, and although I cleared as much as I could from the area I was working, some of it got into the drill. The drill continued to work fine, but after more use I noticed that the air vents were partially blocked.
Today, I took the drill apart, and thoroughly cleaned out the case. I went so far as to remove the entire motor assembly from the plastic case. There was Rockwool just about everywhere.
So now I've got the drill all back together and it's working great. But I have to ask myself: what can I do (besides the obvious) to prevent the drill from getting clogged up with whatever material is in the vicinity of where I am drilling? It would be great if there were a filter that could be placed over the air intake vents in the case, so all I would need to do is clean the filter after each use. But I have never seen such a filter.
What do the pro's do about situations like this? Sure - the pro's probably don't use this particular model drill, but don't all hand drills have vents in the case?
In the future when I work in areas where material can get sucked into the drill, I will do my best to remove whatever material there is, and lay a sheet of plastic over / under it so that it doesn't get into the drill.
Here's a photo of the drill, showing the air intake holes. If I could get some sort of foam filter to fit over this area, I think it would do the trick - but how to do this without interfering with the operation of the drill...
Any ideas?
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-15-2014, 05:25 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Tape some dust mask materials over the intakes. Just a thought.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-15-2014, 05:46 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
taping over the vent holes will cause it to overheat quicker by not getting airflow through it
a better idea is to keep a blow tool handy and simply blast it with air after times when drilling in dusty environments. i do this with all my trim tools at the end of every day this includes saws, routers, nailers and sanders
woodworkbykirk is offline   Reply With Quote
The Following 3 Users Say Thank You to woodworkbykirk For This Useful Post:
Bondo (01-17-2014), DH558 (01-19-2014), ToolSeeker (01-15-2014)
Old 01-15-2014, 06:34 PM   #4
Rewards Points: 894
I think what BigJim means is to tape the dust mask material over the holes, but place the tape so that it does not cover the holes. I think this would work. Dust mask material is much thinner than foam, and is better for filtering that kind of stuff. After all, I can breathe through it. I'll give it a try.
This reminds me that I need to get some more dust masks.
FW
The Following User Says Thank You to Ultrarunner2017 For This Useful Post:
BigJim (01-15-2014)
Old 01-16-2014, 08:41 AM   #5
Rewards Points: 13,750
The black foam that can be cut to size to make furnace filters.
Cheese cloth.
Old 01-16-2014, 09:24 AM   #6
Rewards Points: 894
Thanks guys;
I think you've given me a number of options here. I'll see what works the best for my next project.
FW
Old 01-17-2014, 12:10 AM   #7
In a little over my head
Rewards Points: 706
Stretch an old sock or panty hose over the whole drill. Cut off the toe.
ratherbefishing is offline   Reply With Quote
Old 01-19-2014, 05:17 PM   #8
Rewards Points: 263
If those fibers are floating around I hope your wearing respiratory protection in any case.
Another idea that I've used is very cheap, (and works fairly well, though not great), is an old square house fan with a typical air conditioner filter just taped to the back of it. Just put the fan near your work area and ideally - besides keeping the area cooler if it's hot - any fibers floating up would get sucked into that stronger overall flow and the filter rather than your tools.
Scottg is offline   Reply With Quote
Old 01-19-2014, 08:36 PM   #9
Rewards Points: 236
if your only doing 1-2 holes at a time. taping over the holes will not hurt anything (unless they are pita holes).
or. a paper bag. put some tape on the bottom of it. put the drill inside the bag, poking a hole with the drill bit. the bag then becomes an umbrella.
Fix'n it is offline   Reply With Quote
Clogged exterior foundation drain tile pb940072 Building & Construction 16 05-02-2013 06:42 PM
Toilet Fully Clogged ... still badgerbd Plumbing 4 03-16-2010 10:00 PM
Ridgid 18v vs Dewalt 14.4v xrp vs el cheapo? scottrob Tools 28 05-08-2009 08:45 AM
Kohler wellworths Clogged Chemist1961 Plumbing 20 01-11-2009 07:43 PM
Tools for Residential Building UpComingBuilder General DIY Discussions 5 12-12-2008 06:49 PM
