Demo/Reciprocating Saw Blade Recommendation - Tools - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By joecaption
  • 1 Post By Gymschu
Old 04-20-2014, 09:38 PM   #1
Power Gen/RS Engineer
Rewards Points: 566
I am performing some demo work in my 100 year old house. Today I was removing part of a ceiling to expose joists in preparation for erecting a new partition wall. I realized that at some point in time, someone came through and plastered over the original plaster ceiling and added a double layer of diamond mesh over the existing ceiling prior to installing the new plaster.
What is the best type of blade to use for cutting through the existing layers of plaster and mesh? There are blades that are advertised as being particularly adept at cutting plaster but what if you throw in the metal mesh?
Thanks,
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 04-23-2014, 07:53 PM   #2
Rewards Points: 382
Are you using a reciprocating saw? Use Milwaukie or Lennox blades, they are the best quality. Use the finest tooth blade, at least 18 teeth per inch. A short blade is best, long blades may hit the wall on the other side of the 2 x 4. Go slow, keep a firm hand on the reciprocating saw.
If you are going to use a rotary saw, can you fit a metal cutting blade to the saw?
fireguy is offline   Reply With Quote
Old 04-23-2014, 08:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
hilti also makes great blades but their ease of getting your hands on them is tricky, typically only sold at hilti
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
PaliBob (04-23-2014)
Old 04-24-2014, 05:53 AM   #4
Rewards Points: 14,014
This is one case where I would not attach the top plate directly to the joist, and instead go over the plaster instead, if it's possible to add blocking from above.
An alternative is using a 4-1/2" angle grinder with a diamond blade to make the cut.
Your going to find out a sawsall will cause to much pulling on the plaster and wire and is going to cause some major damage creating a much bigger job then it needs to be.
Bondo likes this.
ptarmigan61 (04-24-2014)
Old 01-03-2017, 08:31 AM   #5
Rewards Points: 8
Re: Demo/Reciprocating Saw Blade Recommendation
If you use a SawZall. the blade about metal usually doesnít have teeth: rather itís some harsh or even milling broker for example silicon carbide or even gemstone which grinds aside the metal.
I recommend you to choose DEWALT DW4856 Metal/Woodcutting Reciprocating Saw.
Understand ahead of time exactly how seriously you would like reduce to become, to help you pick the best dimension
James2016 is offline   Reply With Quote
Old 01-03-2017, 06:33 PM   #6
Usually Confused
lenaitch's Avatar
Rewards Points: 1,986
Huh??
lenaitch is offline   Reply With Quote
Old 01-04-2017, 07:30 AM   #7
Gymschu's Avatar
Rewards Points: 934
Originally Posted by lenaitch View Post
Huh??
Not sure, but I think "James 2016" is trolling. Seems to have an obsession with reciprocating saws. In another thread, Was asking about blades to use in reciprocating saw TO CUT CONCRETE. Someone is bored........
jbfan likes this.
Giving us your general location helps us better help you!
The Following User Says Thank You to Gymschu For This Useful Post:
woodworkbykirk (01-04-2017)
Best Tools for Drywall Removal? neo95gt Drywall & Plaster 59 12-27-2011 12:44 PM
Saw Blade recommendation for Laminate Flooring bowbender6 Flooring 12 07-15-2011 05:43 AM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 06:58 AM
