Deep Stud Finder - 1.5" S. Yellow Pine - Tools - DIY Chatroom Home Improvement Forum
Old 07-26-2014, 07:44 AM   #1
Rewards Points: 37
I have s. Yellow pine lining the walls of our barn (tongue & groove), installed horizontally. Nails were placed at an angle through the tongue and down into the studs. I'm having trouble locating the nails (studs) with my regular zircon stud finder. What can i use to help me get them located better? Something with a better deep scan? Please advise - need studs to install cross ties, hooks, etc... Thank you for the help!
hagler is offline   Reply With Quote
Old 07-26-2014, 08:45 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Strong magnet might work.
Robpo is offline   Reply With Quote
Old 07-26-2014, 09:19 AM   #3
Rewards Points: 14,312
If the walls 1-1/2" thick why would you need to find a stud?
That wall's more then thick enough to support just about anything you would be hanging on it.
Old 07-26-2014, 05:45 PM   #4
Rewards Points: 37
Need to install cross ties which hold the pull of a horse's head...so, into a stud is ideal for strength. What kind of magnet? Or any other ideas for deep stud finder-accurate? Thanks
Old 07-26-2014, 05:50 PM   #5
Rewards Points: 402
I don't know if this will help or not, but I've probably got 4 different brands of stud finders, and none of them seem to work for everything. Most are hit and miss when you use them. Then, I saw this on tv, and got one for christmas. It's the best stud finder I ever had! I even got my dad one next christmas, and he loves it too. It shows you the location, and thickness of the stud, not just the edges. I've used it through panelling and drywall and it worked great. Not sure of it's limitations.
http://www.amazon.com/ProSensor-710-...ds=stud+finder
I tried it, and mine will go through 3/4" wood at the most.
taylorjm is offline   Reply With Quote
The Following User Says Thank You to taylorjm For This Useful Post:
Brokenknuckles (10-10-2014)
Old 07-28-2014, 03:53 PM   #6
Rewards Points: 121
You may want to search google or amazon.com for "Metal Detector Wand"
http://www.amazon.com/Detector-6-inc...detector+wands
jrepp44 is offline   Reply With Quote
Old 07-28-2014, 11:13 PM   #7
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by hagler View Post
........Nails were placed at an angle through the tongue and down into the studs.........
You are in luck because since all common stud finders just find the location of a screw or nail, when you find a nail in your wall you can be pretty sure it is centered because it was a hand drive in a naked stud.
Compare that to how much off stud center drywall screws can be where the installation can be way off.
A strong magnet like this can likely be obtained locally:
http://www.amazon.com/3pc-Super-Stro...+finder+magnet
Disclaimer
& Stay Safe
.....Bob Lavery
1.5" deep wall can I use BX?? walt1122 Electrical 3 03-03-2011 12:41 AM
Antique Yellow Pine Planks: Shiplap? yellowhouse Flooring 0 09-27-2010 10:42 PM
searching for 2 1/4 tongue in groove yellow pine cagtrainer Carpentry 2 09-15-2010 07:06 PM
Yellow pine wood outdoors but covered, paint it or stain it? kindrox Building & Construction 1 05-04-2010 11:32 PM
Yellow Pine pumpman78 Flooring 1 02-02-2007 10:42 AM
