Decent Air Regulator Reccomendations For HF Compressor And Nailgun . Also How To Conn - Tools - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 02:58 AM   #1
decent air regulator reccomendations for HF compressor and nailgun . also how to conn
Sorry for my absolute lack of any expertise on the subject I purchased a compressor and a nail gun from harbor freight recently both are made by central pneumatic nail gun model 98751* http://www.harborfreight.com/10-gaug...ler-98751.html compressor model 67847 http://www.harborfreight.com/25-hp-2...sor-67847.html
I also picked up this http://www.harborfreight.com/16-piec...kit-91501.html after reading both manuals it looks like i will need an air regulator that has a water trap/separator.
I don't mind putting pneumatic oil in the nail gun to keep it working so i'm not too keen on buying an air regulator that has an oiler (even thought it looks like most air regulator are built with a water trap and oiler.) I also see an air regulator that has an oiler and a water trap/separator as just one more thing that could leak air.
Furthermore all the air regulator from harbor freight have horrible user ratings... so i'm trying to shy away from HF's air regulator even though I got my nailgun and compressor from them heh.
Can anyone recommend a quality brand air regulator that has a water separator/filter/trap ?
Or if its smarter to just get an air regulator that has both the oiler and water separator that is fine. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 this one looks good. and I'm guessing it will do the job I'm really doubting i have to spend the $162 for this pricey air regulator http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
My second question has to deal with attaching the new air regulator to the compressor I need to remove the cheap air regulator that came with the compressor seen here on the right http://i100.photobucket.com/albums/m...z/IMG_0296.jpg
But I'm not sure what size wrench i'll need for this bolt / fitting or whatever its called seen here http://i100.photobucket.com/albums/m...z/IMG_0298.jpg I'm not even sure if i need to disconnect that bolt to remove the cheap air regulator that came with the HF compressor? http://i100.photobucket.com/albums/m...z/IMG_0297.jpg
Here is another view of the bolt that i believe needs to be removed for the new air regulator. I tried to loosen that bolt with my adjustable wrench but it is quite a tight squeeze to get the wrench in there and it wouldn't budge...
Any clue on what size wrench would work in the manual it just refers to that part as the "connector" If anyone can recommend an air regulator, and give me some basic instructions on how to remove the current cheap air regulator and install a new air regulator with a water trap / oiler I would truly appreciate it.
EDIT: Added spaces--oh'mike--moderator
plzhelpbuild is offline   Reply With Quote
Old 02-11-2011, 04:30 AM   #2
I don't understand what you say.
londeed_leung is offline   Reply With Quote
Old 02-11-2011, 04:33 AM   #3
I basically need someone to recommend a decent air regulator. and then I need to figure out how to remove the air regulator that came with the compressor. my post looks better here because it was not reformated http://forum.doityourself.com/tools-...ml#post1823450
Old 02-11-2011, 06:29 AM   #4
DIY staff
Rewards Points: 7,174
Welcome to the forum----The enter key add spaces to your text---making it easier to read.
I have edited your post and added some spaces.
See if Campbell Hausfield has the regulator that you need---I've owned many of their compressors and the make a nice unit at a fair price---parts hold up well.--Mike--
Old 02-11-2011, 06:36 AM   #5
DIY staff
For a store that sells regulators and water separators--Look for a automotive paint supplier---
---Auto parts store-----
----industrial supplier---
---compressor repair shop----
I like a separate regulator and water trap----if one fails the other is still good---Depot used to stock replacement regulators---haven't needed one in a long time.
Old 02-11-2011, 07:07 AM   #6
thank you sir. after googling those three terms i will try calling some local compressor repair shops 1st thing tomorrow!
if I don't have any luck there; I will probably look for one of the cambell hausfeld filter/regulator mentioned in the previous post at home depot but i'll call before i drive.
I'm a bit worried about how to attach the new air regulator.
I do need to remove what the manual calls the "output pressure guage" please take a look at the image and notice how the current air regulator which just has a guage is connected almost directly to the tank pressure guage
http://i100.photobucket.com/albums/m...z/IMG_0296.jpg to remove this current output guage to attach the new cambell hausfeld air regulator i would need to unscrew this http://i100.photobucket.com/albums/m...z/IMG_0298.jpg wow i don't know what this keeps reformatting my text
Last edited by oh'mike; 02-11-2011 at 07:38 AM. Reason: poster has a glitch in the system--Mike--
Old 02-11-2011, 07:36 AM   #7
DIY staff
Don't feel bad about the computer---yesterday one of my post lost all of its spaces----might be a hiccup in the program.
I've got to get to work,soon. I'll look at the pictures later---there are two(at least) compressor gurus here---you might be lucky and one will check this out for you.---Mike--
Old 02-11-2011, 07:38 AM   #8
Rewards Points: 79
You already have a regulator - it's attached to the compressor. It's not a fine adjustment but I've been using the built in one on my compressor for years.
For the air filter, what I did was remove the quick connect fitting and get an air filter - like this: http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Has been working well for years.
itguy08 is offline   Reply With Quote
Old 02-11-2011, 08:52 AM   #9
Rewards Points: 56
I have a quick coupler on each of my compressors, quick couples and nipples on each of my hoses, and for use with my nailers, a quick coupler and nipple on a small piggy back filter/regulator. For transport, the filter/regulator goes in a tool pouch, but when ready to use, I plug the filter/regulator into the air compressor, then the hose, and finally the nailer. Mike has already listed the exact places that I would recommend in regard to purchasing what you need. I oil the appropriate nailer, each time I use them, and through the day as necessary, at the nailer, not through a lubricator. I do not use a lubricator for two reasons. First of all, how much oil actually reaches the tool after traveling through 50' or more of hose? In my mind, a lot of it ends up in the hose rather than in the nailer. Secondly, what do you do when you want to use a finish nailer, and don't want oil? Again, in my opinion, the hose already has oil in it. Do you have two sets of hoses, one that you use with a lubricator, and one that you don't? Much simpler, and IMO, efficient, to oil the nailer.
Old 02-11-2011, 03:26 PM   #10
thanks again http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 I'm not sure if this husky will work as the nail gun is using 1/4" tubing & the husky is using 3/8" I'm still a bit confused about how where the water filter sits and how it is supported. Will I be able to hang/hook/connect the water filter directly to the quick coupler on the end of the air regulator on my compressor http://i100.photobucket.com/albums/m...z/IMG_0296.jpg then i hook the pneumatic hose up to the water filter, and then the hose to the nail gun ?
Old 02-11-2011, 08:18 PM   #11
DIY staff
Exactly---make up a water filter and a regulator (if yours is not accurate enough) that can be plugged in before the hose---
We use a separate regulator like that when working in a factory that has compressed air outlets ==the pressure at the outlets is usually to high for out tools--so we plug in our own regulator.
