Dado In Concrete? - Tools - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 11:33 PM   #1
Dado in concrete?
I'm trying to put grooves in concrete, about 1/4" x 1/4", a Dado blade would be perfect, if they were only made for concrete. It might even work, but they're too expensive, and wouldn't last long enough (I'm looking to make many grooves). I also thought the abrasive type of blades stacked up to get the desired thickness might be good, only it would require constant readjustment to keep the grooves at the desired depth since that type of blade wears away. Can anybody make a better suggestion?
Zellarman is offline   Reply With Quote
Old 12-23-2011, 06:06 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,648
Ayuh,.... Use a Diamond blade...
Old 12-23-2011, 08:04 AM   #3
Civil Engineer
Rewards Points: 4,860
Do not stack blades, use a diamond blade as previously suggested, and make two passes using a saw guide. My diamond blade is about 1/8 inch diameter, so two passes makes 1/4 inch.
Daniel Holzman is online now   Reply With Quote
Old 12-23-2011, 09:33 AM   #4
Concrete & Masonry
Rewards Points: 620
Buy a diamond "tuckpointing" blade for a grinder or circular saw. No need to worry about consistency with one of these, and it should be around .220" thick, which will create about a 1/4" width by the time you run it through. You should be able to find a 4.5" blade for less than $50.........
jomama45 is offline   Reply With Quote
Old 12-23-2011, 09:49 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are also segmented "crack chaser" blades available that are thicker than a typical diamond saw blade.
XXX
Old 12-24-2011, 12:16 AM   #6
Thanks Joemama and bud, looks like I'll be going that route. Will post my results.
12/30/2011 update - purchased a relatively inexpensive tuck pointing blade on eBay to fit my circular saw, and it worked perfectly, it cut fairly easily and looks as if the blade should last a reasonably long enough time
Thanks again for the suggestion
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
