#1 |
Wire Chewer
Cutting small trees with sawzall vs chainsaw
I have some small trees that I already cut down by hand but I want to cut into logs and a power tool will be much faster. I'm debating between buying a sawzall, which will be versatile for other uses, or buying an electric chainsaw. Obviously the chainsaw is better for that, but will a sawzall work ok? These aren't that big of trees. The biggest trunk was maybe 8 inchs thick at very most.
#2 |
Framing Contractor
With a good 12 inch blade, a sawzall will cut that in about 60 seconds. A good blade will set you back about 4-5 bucks. We recently built a pole barn and I used the sawzall to cut off the tops of the 6x6 posts. Much more versatile than a chainsaw.
#3 |
Electrical Contractor
I think lenox makes blades for green wood.
The blades have teeth just like a bow saw. I use them all the time, just to keep from digging out the chainsaw, but my sawzall is battey powerd and goes anywhere.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#4 |
Super Moderator
That's the type of blade you need--standard blades bind up in green wood.
New members: Adding your location to your profile helps in many ways.--M-- |
| The Following User Says Thank You to oh'mike For This Useful Post: | mustangmike3789 (07-29-2011) |
#5 |
I used my sawzall to cut out 3 Yew shrubs to about 6" below ground level. It worked great. But as previously mentioned, get the right blade. It took me a long time to get them cut out with a regular blade meant for cutting wood (I didn't know there was a special blade available).
#6 |
I've used both on plenty of occasions.
The recip saw (with the blades like mentioned above) tends to jerk the wood back and forth quite a bit. Probably not as much of a problem if they're already down, but trying to trim smaller limbs doesn't work so great. This is a 12 amp Dewalt, BTW. The chainsaw is much faster. It dominates for this purpose -even the cheapo 120vac, 12" bar I used to use. But of course, this is really it's only purpose. I can't imagine not owning a good recip saw, I'd say go with the recip saw. Keep in mind, they're more susceptible to bind, so get a good setup that won't let the wood pinch the blade. Last edited by GottaFixIt; 07-28-2011 at 06:08 PM. |
#7 |
Sawzall if small and infrequent trimming. Chain saw if regular tree trimming is in your furture
A decent sawzall is probably one of the most usefully tools you should have around the house. Like others have said they make special blades just for pruning. But get one of each blade cause you'll find uses for it. Of course keeping a well tuned gas chainsaw is always the best way. I can have a branch cut long before you can find the battery, if its charged, find the right blade, etc. Its a uni-tasker as Alton Brown would say, but it does its job and does it right. |
#8 |
Wire Chewer
Cool think I will go ahead and go with the sawzall then. I'll check out the available blades and go with the bow saw tooth ones.
#9 |
A Little Of Everything
Cutting small trees with sawzall vs chainsaw |
#10 |
Oldguy
I own 2 chainsaws, a Stihl MS460, and a Stihl 034 super, both GREAT chainsaws. For small stuff I use my Dewalt sawzall in orbital mode with the 12" blade for green wood. It works great.
If you think you can, or if you think you can't, you're probably right. ASE certified master auto tech, Retired. |
#11 |
I have used my sawzall to cut down small trees and even large plants
One time I was out of wood blades and even made it work with a metal cutting blade
#12 |
#13 |
Sounds like a good excuse(I mean reason) for buying a new tool.
#14 | |
Cutting small trees with sawzall vs chainsawQuote:
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 Last edited by Ron6519; 07-29-2011 at 04:47 PM. |
#15 |
Wire Chewer
That's how I see it.
The chainsaw could be nice, but I would probably not use it as much as I could use a sawzall. Too bad it's supposed to rain for most of this long weekend, was going to do this project, guess it will wait... and so much for leaving the dead trees outside to dry.
| Display Modes | |
| Sawzall with Remgrit blade for cutting cement board | Proby | Carpentry | 7 | 08-08-2010 05:47 PM |
| Electric chainsaw - is this a good idea? | CoconutPete | Landscaping & Lawn Care | 21 | 07-24-2010 07:58 PM |
| Tips for landscaping trees on solid rock!!! | Cindyhello03 | Landscaping & Lawn Care | 4 | 06-15-2010 08:01 PM |
