-   Tools (http://www.diychatroom.com/f29/)
-   -   Cutting small trees with sawzall vs chainsaw (http://www.diychatroom.com/f29/cutting-small-trees-sawzall-vs-chainsaw-112273/)
Red Squirrel 07-28-2011 01:04 PM
I have some small trees that I already cut down by hand but I want to cut into logs and a power tool will be much faster. I'm debating between buying a sawzall, which will be versatile for other uses, or buying an electric chainsaw. Obviously the chainsaw is better for that, but will a sawzall work ok? These aren't that big of trees. The biggest trunk was maybe 8 inchs thick at very most.
sixeightten 07-28-2011 01:07 PM
With a good 12 inch blade, a sawzall will cut that in about 60 seconds. A good blade will set you back about 4-5 bucks. We recently built a pole barn and I used the sawzall to cut off the tops of the 6x6 posts. Much more versatile than a chainsaw.
jbfan 07-28-2011 03:48 PM
I think lenox makes blades for green wood.
The blades have teeth just like a bow saw.
I use them all the time, just to keep from digging out the chainsaw, but my sawzall is battey powerd and goes anywhere.
oh'mike 07-28-2011 03:53 PM
That's the type of blade you need--standard blades bind up in green wood.
gma2rjc 07-28-2011 04:49 PM
I used my sawzall to cut out 3 Yew shrubs to about 6" below ground level. It worked great. But as previously mentioned, get the right blade. It took me a long time to get them cut out with a regular blade meant for cutting wood (I didn't know there was a special blade available).
GottaFixIt 07-28-2011 05:05 PM
I've used both on plenty of occasions.
The recip saw (with the blades like mentioned above) tends to jerk the wood back and forth quite a bit. Probably not as much of a problem if they're already down, but trying to trim smaller limbs doesn't work so great. This is a 12 amp Dewalt, BTW.
The chainsaw is much faster. It dominates for this purpose -even the cheapo 120vac, 12" bar I used to use. But of course, this is really it's only purpose.
I can't imagine not owning a good recip saw, I'd say go with the recip saw. Keep in mind, they're more susceptible to bind, so get a good setup that won't let the wood pinch the blade.
Mikelite80 07-29-2011 12:24 AM
Sawzall if small and infrequent trimming. Chain saw if regular tree trimming is in your furture
A decent sawzall is probably one of the most usefully tools you should have around the house. Like others have said they make special blades just for pruning. But get one of each blade cause you'll find uses for it. Of course keeping a well tuned gas chainsaw is always the best way. I can have a branch cut long before you can find the battery, if its charged, find the right blade, etc. Its a uni-tasker as Alton Brown would say, but it does its job and does it right.
Red Squirrel 07-29-2011 07:11 AM
Cool think I will go ahead and go with the sawzall then. I'll check out the available blades and go with the bow saw tooth ones.
DrHicks 07-29-2011 08:07 AM
Good move. It'll be important to get that "big tooth job." I have one, and am amazed what I can saw through!
Rehabber 07-29-2011 11:22 AM
I own 2 chainsaws, a Stihl MS460, and a Stihl 034 super, both GREAT chainsaws. For small stuff I use my Dewalt sawzall in orbital mode with the 12" blade for green wood. It works great.
cbzdel 07-29-2011 01:06 PM
I have used my sawzall to cut down small trees and even large plants :thumbsup:
One time I was out of wood blades and even made it work with a metal cutting blade :)
DrHicks 07-29-2011 01:40 PM
That's kind of like cooking steak in the Crock Pot. :)
Tizzer 07-29-2011 01:55 PM
Sounds like a good excuse(I mean reason) for buying a new tool. :)
Ron6519 07-29-2011 03:45 PM
Black and Decker used to sell a pruning blade for use in a sawzall. The teeth had an aggressive rake to them and worked pretty well for small projects.
http://ecx.images-amazon.com/images/I/31H8QX77VNL.jpg
Red Squirrel 07-29-2011 04:03 PM
That's how I see it. :laughing: The chainsaw could be nice, but I would probably not use it as much as I could use a sawzall.
Too bad it's supposed to rain for most of this long weekend, was going to do this project, guess it will wait... and so much for leaving the dead trees outside to dry. :laughing:
