Cutting Close To Walls... - Tools - DIY Chatroom Home Improvement Forum
Old 01-29-2008, 12:31 AM   #1
Stretch
Cutting close to walls...
I will be replacing subfloors soon. The old subfloor plywood will need to be cut away from the walls...what tool would work best to get close as possible to those baseboard areas? Thanks in advance
scheenstra is offline   Reply With Quote
Old 01-29-2008, 01:11 AM   #2
ICF Construction
subfloor as in the 3/4 or 1 1/8 stuff? Why would you want to replace that?
Anyways, if that's what you are doing, for a close cut you can use an offset for a sawsall, it put's that blade to one side to cut flush without torquing or bending the hell out of the blade.
Chris
Chris Johnson is offline   Reply With Quote
Old 01-29-2008, 05:42 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'd suggest that you also remove the baseboards to get to the subfloor areas to be removed. This will also save them from getting beat-up/damaged, during the Subfloor removal process.
Save the B.B., and re-install after the new subfloor is in.
- Build Well -
Old 01-29-2008, 08:46 AM   #4
flush cut jigsaw blade
RYANINMICHIGAN is offline   Reply With Quote
Old 01-29-2008, 09:12 PM   #5
1.21 jigawatts
macfluke's Avatar
i use a toe-kick saw...
macfluke is offline   Reply With Quote
Old 01-30-2008, 08:06 AM   #6
chainsaw
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
help! my walls are troubled donnamarie General DIY Discussions 5 08-29-2007 12:08 PM
Removing Wood Flooring - Cutting Close to the Edge of the Wall rgmetro Flooring 2 07-12-2007 06:21 AM
