Craftsman Pressure Washer 580.761800 Pump Question - Tools - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 09:51 PM   #1
Craftsman Pressure Washer 580.761800 pump question
I have a Craftsman High Pressure Washer, moidel: 580.761800.
Pump question: I removed 3 nuts holding the pump to the engine. I carefully lowered the pump from the engine. I noticed that there was oil in the hole in the pump where the engine output shaft goes.
The oil level in this hole is about an inch from the top of the pump. The hole diameter is about one inch. The depth of the hole is about 2 inches.
Is there supposed to be oil in this hole? If so, what kind of oil? 80wt gear oil? How full should I fill the oil level? Can I poor this oil out and replace it with fresh oil?
The owner's manual says nothing about pump maintenance regarding oil.
The pump part # is B1262A.
Steve
SteveLake is offline   Reply With Quote
New Well, Pump & Pressure Tank Design Daneel Plumbing 0 06-07-2011 03:28 PM
booster pump/ water pressure problem harpua103 Plumbing 3 12-30-2009 03:26 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 11:11 AM
