Craftsman Devilbiss Air Compressor Cranks SLOWLY But Won't Run - Tools - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 12:41 PM   #1
DIYer
Rewards Points: 244
Craftsman Devilbiss Air Compressor cranks SLOWLY but won't run
I have a 13 year old (5/2001) Craftsman Air Compressor that won't run. It walks. It acts like the electric motor is turning VERY SLOWLY. It does this for about 5 seconds then trips the breaker. Tried a shorter extension cord, tried a different circuit. Let it sit overnight.
I already check the cylinder/piston (which I rebuild 5 years ago) and there is no binding, it moves just fine and looks fine.
I already checked the two contacts inside the switch. I sanded them a bit and it didn't help at all.
How do I troubleshoot the electrical side of this? The motor, the switch, the capacitor, etc?
Info and pics:
mystic_cobra is offline   Reply With Quote
Old 06-28-2014, 12:50 PM   #2
DIYer
Rewards Points: 244
Let's hope it isn't a bad switch. Both Sears and Devilbiss list it for $105. PN AC-0758
Old 07-02-2014, 03:22 PM   #3
DIYer
Rewards Points: 244
Anyone? Anyone ever work on these?
Old 07-02-2014, 03:47 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is the tank pressurized?
XXX
Old 07-02-2014, 08:12 PM   #5
DIYer
Rewards Points: 244
Nope.
Old 07-02-2014, 11:16 PM   #6
Rewards Points: 95
"Tried a shorter extension cord, tried a different circuit."
I remember when I bought my devilbiss air compressor years ago, I tried running it on an extension cord and it did the same thing you described. I had to run a line out to the garage (previously had no power) and plug the compressor directly to that line. I read that unless you have a heavy gauge ext. cord (at least a 10 awg if not bigger) they will not run properly and could trip a breaker. If you are using a heavy gauge ext. cord, I 'm not sure what the problem would be besides maybe a bad switch. Good luck.
Centex2011 is offline   Reply With Quote
The Following User Says Thank You to Centex2011 For This Useful Post:
psal217050 (07-07-2014)
Old 07-03-2014, 12:57 PM   #7
DIYer
Rewards Points: 244
I've been using this compressor with this heavy gauge extension cord for years. I don't know enough about the internals of the switch and capacitor (or the history of these types of compressors) but I'm leaning towards the capacitor.
Old 07-07-2014, 08:00 PM   #8
I want to thank you for this response. Had same issue and once unplugged from the second extension it turned over.
Sent from my LG-E980 using Tapatalk
psal217050 is offline   Reply With Quote
Snowblower: Craftsman vs Poulan wiz561 General DIY Discussions 24 01-31-2015 09:17 PM
1919 Craftsman Bungalow RCB Introductions 1 10-01-2013 08:44 PM
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
Similar to Craftsman, but built in 1900? TOTALN00B General DIY Discussions 3 02-18-2011 11:23 PM
Engine Slowly Loses Power and Dies While Driving slickshift Automotive Repairs 16 01-15-2007 12:34 PM
