Craftsman Circular Saw Cord Repair
Without looking into that model number, let me say this: Some older Craftsman circular saws did indeed have the cords integrated into the switches. Some were soldered, some even had small ring connectors on the wires and then "riveted" to the switch. IF this is your situation, and you are a fairly handy "handyman", then you can replace only the cord using butt connectors. You will have to cut the wiring before the switch, leaving enough wire to attach the new cord. I used to repair these saws for a friend of mine who was a framing contractor. Whenever he would accidentally cut the cord on one of his saws, he would throw it as far as he could then make the statement "I don't want a d*&n" saw that will cut it's own cord". Needless to say, I would just pick the saw up at the end of the day, take it home, repair it and actually sell it back to him. Good Luck, David
