Craftsman Benchtop Jointer-planer - Tools - DIY Chatroom Home Improvement Forum
Old 12-16-2013, 03:02 PM   #1
Craftsman benchtop jointer-planer
I have a new Jointer-planer Mod. # 149.236280. The fence trolley is broken & the fence can not be adjusted without the part (#4540-160-70). I am looking to find one that is available. Unfortunately Sears does not have the part. I will purchase one if available. If not I will consider parting out the machine that I have. I can be contacted at 205-567-6705 or at bobnora@bellsouth.net
bnsurvey is offline   Reply With Quote
Old 12-16-2013, 04:27 PM   #2
Rewards Points: 5,974
Now you know why I won't buy Sears power tools. If this is new why won't Sears replace it?
Old 12-16-2013, 04:40 PM   #3
It is an older purchase that I have just opened up to use. The fence trolley was made of a material that was very porous (like bakelite). It seems to be an excellent machine otherwise. I inherited the machine from a friend who is now deceased. My personal preference in tools that I can afford is Porter-Cable. Thanks for the reply.
Old 12-16-2013, 04:56 PM   #4
DIY staff
Rewards Points: 7,174
We have a bunch of woodworkers here---but next door at woodworking talk,there are hundreds---Woodworking Talk - Woodworkers Forum
Post a picture of the broken part---many of those far east machines are made under many names----so someone might recognize the maker and refer you to a parts source---Mike----
oh'mike is online now   Reply With Quote
Old 12-16-2013, 05:04 PM   #5
Mike; Have uploaded an attachment of the jointer. I cant give you a picture of the part, which practically disintegrated when I put pressure on it. It is a curved part with a groove which slides with the fence when you set the desired angle. Hope this helps.
Old 12-16-2013, 05:09 PM   #6
Rewards Points: 12,824
If you would post the model # someone just might be able to find the part.
If you just want to get rid of it you should be posting on Craigs List not here.
Old 12-16-2013, 05:12 PM   #7
I posted it in my original post. The Model # is 149.236280 & the part is listed as "fence trolley" Part # 4540-160.70. Thanks
Old 12-16-2013, 05:30 PM   #8
DIY staff
I'll look that up----Those are handy little tools---it would be a shame to shelve it for want of a plastic part----I'll be back---
Old 12-17-2013, 07:45 AM   #9
Sorry I wasn't putting you down for it. I was just saying Sears is noted for this they make a tool for a very limited time then quit and also quit making parts for it. I believe the thinking is you used it for a couple years now if it breaks you need to buy a new one.
Old 12-17-2013, 02:53 PM   #10
In a little over my head
Rewards Points: 706
The first three digits of a Sears part # indicate the mfgr. This chart indicates your jointer was made by American Machine and Tool.
http://sears.pammar.net/maker.html
AMT seems to be here:
http://www.amtpump.com/
And a little history here:
http://vintagemachinery.org/mfgindex/detail.aspx?id=29
The following quote makes it sound like you will be fabricating, or working around, the part you need. I have a similar (sized) jointer from Delta. Perhaps a part for the Delta could be modified?
"AMT continued to manufacture home-shop into the 1980s but they also began importing machines from Taiwan and China......For some time, AMT has specialized in the design and manufacture of pumps.....AMT no longer has any information on their old woodworking machinery products, and does not provide support for them"
ratherbefishing is offline   Reply With Quote
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
craftsman jointer mdl 113206 Ed Sullivan Carpentry 1 08-02-2010 04:49 PM
Motor needed for Sears Craftsman jointer pinkoes Tools 1 06-26-2008 11:13 AM
Need part for Craftsman Jointer sherlock Tools 5 11-11-2007 11:24 PM
