Craftsman Air Compressor Won't Run - Tools - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 09:56 PM   #1
I have a Craftsman electric 15 gallon air compressor, horizontal. Model 916-167242. It was plugged into the neighbor's house while we were putting up a fence and tripped the breaker. He reset the breaker before I had a chance to turn off the compressor. As soon as he did, the compressor started then immediately stopped. Now it won't turn on. I found the manual online and there is no mention of any fuse. I've read something online about a "run capacitor". I'm unfamiliar with that, but I'm a quick study and will be looking into that momentarily.
Any suggestions for me in the meantime?
Thanks much,
Mark
machouinard is offline   Reply With Quote
Old 03-13-2013, 10:12 PM   #2
Rewards Points: 13,300
http://www.mastertoolrepair.com/sear...p-p-22886.html
That style of motor does not have a start cap.
Old 03-13-2013, 10:15 PM   #3
Rewards Points: 5,974
Did anyone look for a reset button?
Old 03-13-2013, 10:20 PM   #4
I have since discovered there is no run capacitor on this machine.
There does not appear to be a reset switch either.
Old 03-13-2013, 10:26 PM   #5
Try something simple.
Drain the air out of the tank and see it will now start.
Old 03-13-2013, 10:29 PM   #6
I've drained the tank already. I'm stumped.
Old 03-13-2013, 11:33 PM   #7
So there is no fuse in the compressor. No run capacitor. I've tried multiple outlets, with and without extension cord(s). Could flipping the breaker while the power switch is on simply fry this thing?
Old 03-13-2013, 11:35 PM   #8
Rewards Points: 248
How do the wires look? Charred burnt looking at al?
jburchill is offline   Reply With Quote
Old 03-13-2013, 11:45 PM   #9
Lord of Slums
Rewards Points: 1,974
tripped breaker for reason, not farmilair with your machine, the ones i torn down were junk that was unrepairable, or simple part more than whole new compressor
mj12 is offline   Reply With Quote
Old 03-20-2013, 10:36 PM   #10
Thanks much,
Mark
Not sure if this will be helpful but there is a recall on the 15 gal Craftsman compressor. I have the same compressor, 3HP /1.5 HP running 150 p.s.i. Apparently the recall says the motor can catch fire. I recieved the recall probably 4 months ago. But due to it running fine I never sent it in. Maybe it damaged the motor somehow.
Dave
Lowcountrydave is offline   Reply With Quote
The Following User Says Thank You to Lowcountrydave For This Useful Post:
machouinard (04-08-2013)
Old 03-17-2014, 04:21 PM   #11
Guess I forgot to get back to this. After many phone calls to many service techs who all assured me there was no fuse, I pulled off the housing and removed the motor. On the bottom of the motor, buried in electrical tape, was a 30A blade fuse, blown.
Perhaps this will help someone in the future.
The Following 3 Users Say Thank You to machouinard For This Useful Post:
curtd (03-29-2014), PaliBob (03-17-2014), ratherbefishing (03-18-2014)
Tags
compressor , fuse
Snowblower: Craftsman vs Poulan wiz561 General DIY Discussions 24 01-31-2015 09:17 PM
Porter-Cable or Craftsman Drill Dilema cprice12 Tools 19 02-16-2012 08:00 PM
Our House: A 1913 Craftsman OurHouse Introductions 9 06-26-2011 10:37 PM
Similar to Craftsman, but built in 1900? TOTALN00B General DIY Discussions 3 02-18-2011 11:23 PM
Craftsman 19.2 problems..please help lairdness Tools 12 08-17-2009 10:14 AM
