-   Tools (http://www.diychatroom.com/f29/)
-   -   Craftsman Air Compressor -- Getting Lazy!!! (http://www.diychatroom.com/f29/craftsman-air-compressor-getting-lazy-56159/)
ShortOnLuk 10-28-2009 05:15 PM
I have a 2hp 26 gallon Craftsman Air Compressor (919.167280) that recently started acting up. It runs fine, but after it shuts off (upon reaching max pressure) it won't start up again unless I wait several minutes (10 - 15). If I try to start it earlier than that, it tries to start, but settles into a whiny sort of noise. If I wait a while and turn it on, it starts up like the day I got it.
Any idea how I can identify where the problem is?
47_47 10-29-2009 06:40 AM
Check your unloader valve.
Maintenance 6 10-29-2009 06:44 AM
There is an unloader valve that bleeds the pressure off of the pump so that the motor does not have to try to start against pressure. Sounds like that valve has gotten sticky and isn't bleeding off. When the pump shuts off after reaching pressure, you should hear it blow the air out of the line.
ShortOnLuk 10-29-2009 05:11 PM
Thanks. I started pulling everything apart and reached a point where I could go no further. It looks like Craftsman didn't want anyone to mess with this since the unloader valve (referred to in the manual as a pressure release valve) is a part of the switch assembly and won't come out even when the screws are removed. I was able to pull the check valve and that's operating freely. I'm going to run it some more plugged directly in to the wall to see if maybe the extension cord is the culprit. I've used the same one for years, but maybe it's on its last leg. If not, it looks like I'll be purchasing a new switch assembly. Thanks again.
ShortOnLuk 11-02-2009 01:15 AM
It was definitely the extension cord. I ran it plugged in directly and also took it to a neighbor's house (to blow out his sprinkler system) and ran it there without issue. Thanks for the suggestions though... if nothing else, it made me more familiar with the tool, which is always a good thing.:thumbup:
Thurman 11-19-2009 04:22 PM
You have a 2HP, 26 gallon tank air compressor that you are running using an extension cord? Excuse me, but that's not good business. Being as you are using an extension cord, is this a 110 volt compressor? Maybe it's time to consider a dedicated circuit. David
