Craftsman 7 HP Pressure Washer Model 580.762601 - Tools - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 07:06 PM   #1
Craftsman 7 HP pressure washer model 580.762601
My pressure washer engine won't run beyond 5-10 seconds, cleaned the carb, checked the plug, new gas, new filter, oil level OK, pump oil level 3/4 full. Before this issue it always shut off after a 5-10 minutes use, just had to wait to restart and it was fine. Don't know why it might be heating so fast or have low oil pressure, there is lots of water pressure going to the pump and oil level is good, it statrs fine on first pull and seems like it is getting fuel but just shuts down (like an automatic kill switch) after a few secons. Would a faulty oil pressure switch cause this? Running out of ideas, please help!
Princessfreddy is offline   Reply With Quote
Old 11-14-2011, 11:56 AM   #2
I had a similar issue with a Honda engined pressure cleaner. It would run maybe 2 or 3 minutes then quit. Right before it quit it would spit and sputter kind of like water in the fuel. I cleaned the tank and checked the plug.. engine still run poorly. I eventually changed what looked like a good,clean plug and the
engine ran perfectly.
So with plugs looks don't always mean good.
Good luck
Idmason60 is offline   Reply With Quote
The Following User Says Thank You to Idmason60 For This Useful Post:
Thurman (11-14-2011)
Old 11-14-2011, 04:41 PM   #3
Good luck
Old 11-15-2011, 01:16 AM   #4
Location: 16 Tower Office Park, Woburn, Massachusetts 01801 USA
Check and clean your plug then reset i hope it will run other wise go to the expert mechanic who can handle this issue perfectly.......
Last edited by Gary in WA; 12-17-2011 at 10:54 PM. Reason: removed ad link per forum rules.
Daimer is offline   Reply With Quote
honda pressure washer electricman General DIY Discussions 2 06-07-2011 06:52 PM
Craftsman pressure washer 6.5hp Plunge Painting 3 06-06-2011 07:20 PM
honda pressure washer trouble electricman Automotive Repairs 6 06-03-2011 07:21 AM
Pressure Washer Question DIYchick Tools 8 02-05-2008 05:44 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 01:43 PM
