Craftsman 30 Gal. Compressor - Tools - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 06:45 PM   #1
craftsman 30 gal. compressor
my compressor does not get more than 30 psi but keeps running no visible leaks
roland16 is offline   Reply With Quote
Old 09-03-2012, 06:50 PM   #2
Lavid2002's Avatar
Rewards Points: 85
How old is said compressor? Take a bottle with some soapy water in it and spray around to see for leaks. Leaks will make bubbles, be generous with the spraying.
There has to be a leak somewhere, even if it's out of the head or a bad flap valve.
Lavid2002 is offline   Reply With Quote
Old 09-03-2012, 06:51 PM   #3
Rewards Points: 212
Just to ask the obvious before we overlook it --- you have adjusted the regulator right?
General info on air compressor at http://www.popularmechanics.com/home...icient/1275131
orange is offline   Reply With Quote
Old 09-03-2012, 06:59 PM   #4
Rewards Points: 13,458
May want to add the model # and serial # to your post.
It could be a number of things, the line from the tank to the pressure switch leaking, piston rings worn out, leaking drain valve on the bottom of the tank , bad check valve, broken reeds, ect.
hand drive (09-03-2012)
Old 09-03-2012, 07:34 PM   #5
jschaben
Rewards Points: 502
Sounds like a stuck or leaky valve. If the regulator was set to 30 #'s it would shut off when it got there. Model number would be helpful.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Bogged down Craftsman compressor - Part 2 spavined Tools 7 01-16-2012 02:30 PM
craftsman air compressor hopps Electrical 2 04-14-2011 10:15 AM
Bogged-down Craftsman compressor spavined Tools 14 03-05-2010 05:13 PM
Craftsman air compressor blowing breaker Frankenberry Electrical 38 10-10-2009 07:02 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
