-   Tools (http://www.diychatroom.com/f29/)
-   -   craftsman 30 gal. compressor (http://www.diychatroom.com/f29/craftsman-30-gal-compressor-155729/)
roland16 09-03-2012 07:45 PM
my compressor does not get more than 30 psi but keeps running no visible leaks
Lavid2002 09-03-2012 07:50 PM
How old is said compressor? Take a bottle with some soapy water in it and spray around to see for leaks. Leaks will make bubbles, be generous with the spraying.
There has to be a leak somewhere, even if it's out of the head or a bad flap valve.
orange 09-03-2012 07:51 PM
Just to ask the obvious before we overlook it --- you have adjusted the regulator right?
General info on air compressor at http://www.popularmechanics.com/home...icient/1275131
joecaption 09-03-2012 07:59 PM
May want to add the model # and serial # to your post.
It could be a number of things, the line from the tank to the pressure switch leaking, piston rings worn out, leaking drain valve on the bottom of the tank , bad check valve, broken reeds, ect.
jschaben 09-03-2012 08:34 PM
Sounds like a stuck or leaky valve. If the regulator was set to 30 #'s it would shut off when it got there. Model number would be helpful.
