Crafstman Generator With 8 Hp Tecumseh - Tools - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 06:16 AM   #1
Crafstman generator with 8 hp tecumseh
How do you wire an on off switch on a generator
Tommytattoo is offline   Reply With Quote
Old 03-29-2013, 06:20 AM   #2
Generator
Its a craftsman 4000 watt generator I have no manual and can't seem to find on . Can't turn the gen off
Old 03-29-2013, 08:05 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 660
Ayuh,... It just has to ground out the ignition....
The Following User Says Thank You to Bondo For This Useful Post:
Tommytattoo (03-31-2013)
Old 03-29-2013, 08:13 AM   #4
Rewards Points: 13,300
Model #?
Was there a switch on it at one time?
Both of mine have switches but I never use them. Reason being is I shut off the fuel instead and let it run out of fuel so there's no fuel left in the carb. to go bad.
Old 03-30-2013, 08:55 AM   #5
Originally Posted by Mr Chips
http://www.lawn-mower-shop.com/carb1.htm
http://www.psep.biz/store/tecumseh_carburetors.htm
You might want to just price out a replacement carb. Probably not very expensive, and easy enough to swap one out, even for a rookie
I have a Tecumseh generator that won't turn off from the on off switch any sugestions
Old 03-30-2013, 09:00 AM   #6
Chrafstman generator with 8 hp tecumseh
Benny won't turn off withe the on off switch. Any suggestions
Old 03-30-2013, 09:27 AM   #7
Going to have to OHM out the switch to see if it failed.
Disconnect one of the wires first.
Old 03-30-2013, 10:54 AM   #8
Rewards Points: 1,294
Chances are good that switch just shorts the magneto. The vibration probably shook the wire loose. The newer stuff might be using a different method though
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 03-30-2013, 11:11 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
Pull the plug wire to kill it until you can get the switch fixed.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 03-31-2013, 07:22 AM   #10
Originally Posted by joecaption
Model #?
The model number for my generator is 580326980. It's a craftsman 4000 watt with a Tecumseh 8 hp engine. Also trying to find info out on governor adjustment. Genny was given to me for free but not running. I rebuilt the carb. But someone played with the governor it's running now but idling to high with no load on it. Any info would be very much appreciated
Old 03-31-2013, 01:36 PM   #11
Bondo's Avatar
Rewards Points: 660
Ayuh,... Unless it's a Hi-end set, most usually "Idle" at Wot, against the governor...
Without a electro-mechanical "Idle" unit, I doubt it's Supposed to "Idle"...
Old 03-31-2013, 04:11 PM   #12
With a small unit like that there is no adjustment. It's all done by the spring on the carburetor.
Differant springs are used for differant uses.
Tommytattoo (04-01-2013)
Old 04-01-2013, 06:12 AM   #13
That makes sense. As long as it maintains the set speed of around 3400 rpm it should b ok. I will try it with a heavy load to see if it maintains the correct speed. Thanks
1997 MTD w/ 8 hp tecumseh engine teamcampreder Landscaping & Lawn Care 8 02-21-2013 08:49 AM
6.5 Tecumseh kick back while pull starting - how adj valves toro63 Tractors & Mowers 1 07-31-2012 07:08 PM
Toro Recycler mower w/ Tecumseh 6.5 engine - starts and immediately dies Pickngrin Landscaping & Lawn Care 40 07-14-2012 07:43 PM
How To Rebuild Tecumseh Electric Start? asian432003 Landscaping & Lawn Care 3 09-13-2009 06:34 PM
tecumseh 8hp engine billkemp Landscaping & Lawn Care 1 05-11-2008 08:27 AM
