Cordless Trimmer Motor Bad? - Tools - DIY Chatroom Home Improvement Forum
Old 05-18-2014, 01:38 PM   #1
New House Newbie
Rewards Points: 95
Cordless trimmer motor bad?
Is this motor bad due to the shaft (armature?) riding loose in the case? When it spins it rides all the way around the case opening. This while started as a rest of slow turning of the motor; almost as if it was only running on 12 volts instead of 24. Also, the motor does not always start when I press the trigger and have to hand start to get the motor to spin.
Batteries have been benched tested and are good and I get 26 volts at the motor leads.
Should I order a new one or can this be repaired?
Cordless trimmer motor bad?-image-2900474362.jpg   Cordless trimmer motor bad?-image-4103275367.jpg
C_J_GO is offline   Reply With Quote
Old 05-18-2014, 02:31 PM   #2
Rewards Points: 13,750
Checked the brushes to make sure there not worn out?
Made sure there's not trash causing then to stick?
Checked the armature for shorts and cleaned the segments?
Old 06-04-2014, 02:04 AM   #3
Rewards Points: 744
That motor appears to be physically damaged. Armature's center shaft should be centered, supported by a bushing or bearing.
Seattle2k is offline   Reply With Quote
Which cordless trimmer to buy Scalerwave Tools 6 05-20-2014 09:24 AM
cordless drill selection help needed JackB Tools 30 10-24-2012 07:04 PM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 04:20 PM
Cordless Cellular Blinds kristan Interior Decorating 8 01-17-2010 09:33 PM
Repair help w/ a cordless trimmer kennykenny Tools 6 06-28-2009 08:20 PM
