Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 07-25-2012, 06:36 PM   #1
It was a dark and stormy
Yoyizit's Avatar
Cordless drills, take two
Drilliing many holes needs energy delivery = watt-hour delivery = voltage x amp-hour delivery
Fast drilling of holes needs power delivery = watts = volts x amps = high (rpm x torque)
This example Ragone chart
http://www.google.com/imgres?imgurl=...Q9QEwAw&dur=95
shows that, for a battery of a given weight, you can't have a battery optimized for power delivery and energy delivery at the same time, so you are kind of forced to decide which is more important.
If weight is important, this same chart can steer you toward a weight/energy/power tradeoff.
The trick is to find a chart showing all the battery technologies commonly used today in cordless tools.
In the event of a tie between tools, for which do you get the more w or w-h or the less weight, per dollar spent?
The Following User Says Thank You to Yoyizit For This Useful Post:
toolaholic (07-26-2012)
Old 07-26-2012, 07:18 AM   #2
Boy your really into science of batteries. I use the Milwaukee 18 nicad/ V18s for the heavier stuff if they don't cut it, out comes the corded stuff. And some projects like drilling out tree stumps and drilling holes in the ground with a earth auger dictate passing on cordless and going straight for the cord!
toolaholic is offline   Reply With Quote
Old 07-27-2012, 09:33 AM   #3
Yoyizit's Avatar
Yeah, the cord gives you high watts and almost infinite watt-hours.
opinions on cordless nailers princelake Tools 11 05-19-2012 12:18 PM
Help choosing between these cordless power drills and why for a 1st timer? amlodipine Tools 21 09-24-2011 12:23 AM
Confused on the cordless drills scarrylarry Tools 6 07-15-2010 04:26 PM
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
Any info on Hitachi cordless drills? theltimatepartyjams Tools 3 12-16-2008 02:24 PM
