Cordless Drill Help??? - Tools - DIY Chatroom Home Improvement Forum
Old 06-06-2013, 12:44 AM   #1
Rewards Points: 89
Cordless drill help???
Hi,
Can someone please recommend a good durable cordless drill? Should I get a 12v or 18v? Do I need a hammer drill or just regular? I'm looking for a pretty much all purpose drill.
Thank you everyone in advance!
bcdinh is offline   Reply With Quote
Old 06-06-2013, 01:21 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,824
This thread should pretty much answer your question
Ryobi one+
The Following User Says Thank You to ddawg16 For This Useful Post:
bcdinh (06-06-2013)
Old 06-06-2013, 10:20 AM   #3
Rewards Points: 89
Should I get the one will the hammer drill or a regular one? I won't be drilling into concrete that much but do you think it is a good feature to have?
Old 06-06-2013, 10:23 AM   #4
Rewards Points: 736
"that much" means you'll still do it. Seems like a good feature to have if you're going to use it some day.
TheBobmanNH is offline   Reply With Quote
Old 06-06-2013, 10:25 AM   #5
JOATMON
ddawg16's Avatar
If your like most of us....drilling into concrete will be maybe 1% of the drilling.
Start keeping an eye out for the sales...get a combo kit....drill, sawzall, circular saw and one or two batteries....then as you need the tool...buy it.
Old 06-06-2013, 10:42 AM   #6
dmclean701's Avatar
Rewards Points: 152
I got the 10.8v Makita drill set several years ago and use it often. You get a drill with 2 speeds and an impact driver. They are small and work great. The Li-ion batteries still work. Don't get a drill with a Ni-cad battery, they are junk. If you're going to drill concrete once in a while just get a low price corded drill for that.
Sent from my iPad using DIY Forum
dmclean701 is offline   Reply With Quote
Old 06-06-2013, 11:01 AM   #7
funfool's Avatar
Rewards Points: 534
IMHO, the hammer action on a cordless drill is very helpful for driving screws, is the hammer that helps start the screw. Really is worthless for drilling into concrete.
Although you can drill small holes in concrete with them.
I would ask yourself what you will use the tool for?
A cordless drill makes a lousy screw gun, but works.
A cordless screw gun makes a lousy drill, but works.
I have a drill, once I bought the screwgun, I rarely use the drill.
14 volt vrs 18 volt, the newer lithium batteries are pretty light and not much of a problem.
My dewalt with the ni-cad batteries, I chose the 14 for a couple of reason. They both have the same amount of torque and do the same job. The 18 is bulkier, more weight to lug around, counts when you have a 25 pound tool belt on already, now strap a drill to it.
If I drill a hole with my 14 and set the drill aside, it will stand up on the battery pack.
A 18 is so awkward it will not stand up and need to make room to lie it down on the floor somewhere. That was the deal breaker on the old ni-cad 18 for me.
funfool is offline   Reply With Quote
Old 06-06-2013, 11:09 AM   #8
Rewards Points: 736
Worthless? I haven't done it a ton, and certainly not professionally (and it looks like you could be a professional), but for the typical DIY-er who's going to drill a half-dozen to a dozen holes in concrete for some TapCons or something, a decent cordless hammer drill is perfectly adequate, and far from worthless.
Old 06-06-2013, 12:55 PM   #9
Rewards Points: 89
Thank you everyone for your responses. I am deciding to buy the Milwaukee cordless drill.
Does anyone have experience with this drill?
http://www.homedepot.com/p/t/2020437...5#.UbDMWkDVDA0
Old 06-06-2013, 06:09 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
its not bad.. just make sure you get the 3.0 amp batteries or the new 4 amp batteires. the slimpacks have very little run time on them..
one other thing to mention is to make sure you put the drill into low speed when drillling holes larger than 1" so that its using a lower gear that will deliver more torque.. the milwaukee drills are bad for the gears stripping on them.....
i dont want to see a resonse to use the ryobi's instead because its the low end line from the same parent company as milwaukee...
woodworkbykirk is offline   Reply With Quote
Old 06-06-2013, 07:35 PM   #11
Rewards Points: 5,974
Gotta put my vote in for Ridgid. If for no other reason than lifetime warranty on batteries. Yes get hammer drill if you only need it once it will be worth it. Funfool if you can't tell the diff in a hammer drill in concrete there is something wrong with your drill. Yes get the 18 lith. Don't let anyone talk you into NiCad batteries they will be cheaper but they are being phased out and are going to become hard to find.
Old 06-06-2013, 09:32 PM   #12
Rewards Points: 4,796
WTF?
jeffnc is offline   Reply With Quote
Old 06-06-2013, 09:37 PM   #13
I know this might run up the price a little, but some things to consider:
- hammer drill is useful even if you use it rarely
- once you use an impact driver to drive screws, you will wonder how you ever lived without it.
- a combo pack that comes with 2 batteries makes all kinds of sense. Basically it means you will never run out of battery power virtually no matter what you're doing.
- higher milliamp ratings are nice, but not necessary if you have 2 batteries, especially if you're not pounding away like a contractor.
I have this one, which I love
http://www.homedepot.com/p/Makita-18...g#.UbFHJNg2njI
The battery charger is great. However you would be fine with the smaller battery version (still 18v though). Great kit for the price.
http://www.homedepot.com/p/Makita-18...g#.UbFHXNg2njI
Old 06-06-2013, 09:58 PM   #14
retfr8flyr's Avatar
I have always had great service from Milwaukee tools. I have the V18, earlier version, of that drill and it has given me trouble free use for about 5 years. I have other M18 tools and they are even better than the V18, better battery.
retfr8flyr is offline   Reply With Quote
Old 06-06-2013, 11:17 PM   #15
funfool's Avatar
Rewards Points: 534
All ya all quit picking on me
I do think the hammer action for drilling holes in concrete with a cordless drill is worthless.
I can use my 1/2" dewalt corded drill on slow speed and drill a hole in concrete faster then my dewalt cordless on hammer.
I do think the hammer action is good for drilling screws, but the rpm is to slow to make a decent screwgun.
Sigh
cordless drill selection help needed JackB Tools 30 10-24-2012 07:04 PM
Will a cordless drill be able to drill through brickwork? Homervanderjazz Tools 14 02-08-2012 10:35 PM
Need advice on cordless drill brand with a battery life of over 5 years?? stanlam Building & Construction 7 08-09-2010 11:31 AM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 03:18 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
