Copper Pipe Soldering Tool
Never have tried one of these, but in watching the video the heat is being applied to the wrong side of the connection, sweating a joint pulls the solder into the joint. Appears to be one of those things that someone who is not capable of doing a connection traditionally would buy and put on a shelf.
The first question I would have at 2200 Watts, how would that work with a bit of water in the pipe, like we all get when you are doing real life plumbing.
I don't think I would be willing to spend the $140 bucks to find out.
Mark
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
