Confused On The Cordless Drills - Tools - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 01:02 AM   #1
Rewards Points: 97
Confused on the cordless drills
Could someone explain to me what is the difference between the following.basically what each is better suite tou what type of work
#1 A cordless drill
#2 A cordless Drill Driver
#3 A cordless Impact Driver
#4 A cordless impact wrench
#4 Hammer drill I do have a bit of an uderstanding on this as I think it is meant for concrete drilling
Many Thanks
scarrylarry
scarrylarry is offline   Reply With Quote
Old 07-05-2010, 01:33 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
#1 A cordless drill
just what it says it is. Works good for making holes
generally has a slow speed and a clutch. The slow speed is more controllable for driving the fasteners to a specific depth and the clutch allow one to set effectively how much torque is applied to the fastener
most I have seen have a 1/4" hex quick release chuck. Allows faster changes of bits. The impact value also provides for much greater torque so a larger screw or even lag can be driven.
similar to an impact driver but intended to be used with sockets (like you would use with a ratchet). Made to remove or tighten nuts and bolts. Generally larger and imparts more torque than an impact driver.
imparts a hammering action along with the rotational action. Yes, for drilling into concrete and such. Many can be set to use just the rotational action or the hammering action. This way you can use it just like any other drill or you can use it as a power chisel.
Old 07-05-2010, 03:05 PM   #3
Rewards Points: 97
Thanks Nap!
scarrylarry
Old 07-05-2010, 03:16 PM   #4
Originally Posted by scarrylarry View Post
#4 Hammer drill
Cordless?
Old 07-05-2010, 04:37 PM   #5
nap
You talking to me?
nap's Avatar
Originally Posted by Yoyizit View Post
Cordless?
Sure.
Old 07-08-2010, 03:18 PM   #6
Handyman
Rewards Points: 512
Also, less chance of screw/lag heads from camping off
canadaclub is offline   Reply With Quote
Old 07-15-2010, 04:26 PM   #7
The best thing about an impact driver is: if the bit bogs down, the tool doesn't swing around and try to wrench your shoulder out of its socket!
ericb1960 is offline   Reply With Quote
Circular saw -- 6 1/2" Vs 7 1/4" & cordless Vs corded whataboutj Tools 9 02-26-2010 05:20 PM
Cordless Cellular Blinds kristan Interior Decorating 8 01-17-2010 10:33 PM
Confused about Sub Panel stqevo Electrical 28 10-02-2009 12:04 AM
Any info on Hitachi cordless drills? theltimatepartyjams Tools 3 12-16-2008 02:24 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 08:26 PM
