Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-03-2012, 09:48 AM   #1
Concrete Wall Demo
Need ideas for what tools/equipment would work best to demo an old concrete wall. Its outside, but in a tight area between two homes. It has steel bars inside & concrete was made with beach sand many years ago so is now crumbling. Ideas? Must get down. Thanks!
tinaanddave is offline   Reply With Quote
Old 02-03-2012, 10:31 AM   #2
Master General ReEngineer
Bondo's Avatar
Concrete Wall Demo
Ayuh,... A jackhammer, 'n a hacksaw for the steel...
Old 02-03-2012, 11:03 AM   #3
concretemasonry's Avatar
Concrete Wall Demo
The mistake of using beach sand is actually a blessing when it comes down to removing the wall.
Dick
concretemasonry is offline   Reply With Quote
Old 02-03-2012, 01:34 PM   #4
Stuck in the 70's
Blondesense's Avatar
Concrete Wall Demo
You might check out these two old threads:
Expanding explosives
Concrete Demolition
Old 02-03-2012, 07:09 PM   #5
Concrete Wall Demo
Rotary hammer with hamming only feature to use a chisel with! SDS plus might be to small! Get a spline or SDS max rotary hammer! Also Bosch makes a nice demo SDS plus hammer that is small but packs a nice punch! It is model no 11320vs chipping hammer!
toolaholic is offline   Reply With Quote
How to insulate 1' concrete wall that meets 8' studded wall Truth Insulation 7 01-16-2012 09:14 PM
Exterior wall on concrete pad - waterproofing under wall? (Illustration included) JustADoc Building & Construction 12 08-18-2011 06:07 PM
concrete stub wall daltinator Building & Construction 2 03-29-2011 09:58 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
