Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 03-27-2012, 08:16 AM   #1
Concrete Grinding
Does anyone have any recommendations on grinding or scarifying concrete?
I have a 365 sq ft concrete terrace that I am looking to set tile on so I am trying to get it down to bare concrete. The concrete has some industrial strength adhesive bonded to the concrete from the outdoor carpet I took up along with at least 2 layers of paint, most likely oil based. I’ve tried scrapping, chemicals, pressure washing and a handheld grinder with some sort of scrapping/grinding wheel that only heated up the adhesive and gummed up the wheel pretty quick.
The two suggestions which I am headed towards are an industrial grade floor buffer with most course wheel I can get or a walk behind concrete grinder/scarifier. Both options are $200 plus rental. The buffer I am afraid will gum up like the hand grinder I tried. The scarifier sounds excessive.
Any other suggestions? I have learned that chemicals are a no-no for thin-set.
Thanks,
John
onthejob is offline   Reply With Quote
Old 03-27-2012, 12:56 PM   #2
bbo
Concrete Grinding
I would rent the grinder. like you said, the buffer will gum up.
bbo is offline   Reply With Quote
Old 03-27-2012, 03:58 PM   #3
Concrete Grinding
The ideal product is called Diamabrush which is a wheel under a scrubbing machine that has flaps of diamond coated metal. It works like nothing else because the diamonds cannot clog. Google Malish Corporation and find a local renter, I believe Home Depot is going to have them.
In the meantime if you want more information about preparation go to http://www.situp.com.au/How%20to%20c...20sealing.html
Diamond is offline   Reply With Quote
Old 03-29-2012, 11:47 AM   #4
Concrete Grinding
The rental company said the concrete grinder/scarifier will gum up and be useless just like a buffer. No one in my area rents shotblasters which sounded like that could be my best option. Someone suggested a hammer drill with the chisel tip. Might have to give that a try. I like this Dimabrush head but I can't find it anywhere locally. Looks exactly what I need. I have an email into the company.
Old 03-29-2012, 11:50 AM   #5
bbo
Concrete Grinding
Almost sounds like group spam to me.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 09:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 10:08 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
