#1 |
compressor water
I run my compressor threw two water filters, one rite on then a water filter and oiler. I still get water. How do I fix this?
#2 |
Union HVAC Tech.
compressor water
Drain the tank more often.
#3 |
compressor water
Thanks, I do keep the tank clear. I can leave it open a little and I still get water. Any other ideas? Mack
#4 |
Woodworker and Contractor
compressor water
what are you doing that a little water causes problems? Are you spraying paint with and oiled compressor? If you realyu nesed it dry I have had luck with disiposable filter for singel use paint spraying.
#5 |
compressor water
Thanks for getting back to me. I have two water filters and a oiler, I still get water. I was just trying to see if I was doing some thing wrong in the way I have it hooked up. Iam just using air tools for now, water comes spitting out. I live near Ft. Lauderdale could be the heat.
| Display Modes | |
