Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-23-2009, 08:45 PM   #1
compressor stopped working!
I have a relatively new Makita MAC2400. It's been a delight for a good year or so and never given me any troubles. Have probably only used it a dozen times for a few hours or so.
Well, had it fired up yesterday, filled, turned out I didn't get as far as I needed to, turned it off and drained it.
Today turned it back on, pressurized it, and left it to sit for a few hours.
I used the blowgun attachment to clean some dust off, and it didn't repressurize. Tried multiple different outlets and cords, turned it on and off, fiddled with the regulator control, nothing. Just woulldn't turn on.
Saw the oil was looking a little sludgy, and low. Added a bit to it, and brought it inside about an hour ago to warm up.
Still doesn't turn on!
Any ideas what is going on? It hasn't been banged up or dropped or anything. Nothing that would have caused the wiring to disconnect or anything like that.
No idea. need this to work!
Thanks.
wombosi is offline   Reply With Quote
Old 02-23-2009, 09:00 PM   #2
sorry guys. just fixed it.
found the manual online.
turns out there is some kind of thermal overload "reset" button. was able to find it andpush it, and all is well again!
yay.
Old 02-26-2009, 12:54 AM   #3
Here is a question....did you ever break in the compressor? Did you ever change the oil? If so what did you use for oil, what Makita reccomeneded...
TBFghost is offline   Reply With Quote
No heat but working AC xevier69 HVAC 4 01-30-2009 06:31 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 02:32 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
