Compressor To Run Roofing Nailer. - Tools - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 09:15 PM   #1
Post
Compressor to run roofing nailer.
Would this air compressor be sufficient to run a roofing coil nailer rated at 2.5CFM @ 90 psi ? Going to be shingling my roof soon, which is 52 feet by 22 feet.
3.4 Gallon
4.9 CFM @ 40 PSI
3.6 CFM @ 90 PSI
2 HP
Max. pressure: 125 PSI
110V/60 Hz electric motor
Oil lubricated direct drive pump is quieter than oil-free compressors
Includes: regulator and dual gauges
Suitable for light duty applications and general household use
ASME safety valve with thermal protector, pressure gauge, quick coupler
Motor with copper wiring, rust-resistant powder coat finish
Max. motor output: 1200W (40W)
No load speed: 3,400 RPM
Bore and stroke: 48 x 38 mm
http://www.princessauto.com/workshop...air-compressor
slimjim is offline   Reply With Quote
Old 08-17-2011, 09:56 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Slim,
that compressor should work fine. Air nailers don't suck up near as much air as continuous running tools like grinders.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 04:49 PM
Manufacture date code for Bostitch RN 46 roofing nailer marvin81 Building & Construction 1 05-04-2011 03:53 PM
Roofing Nailer Question billythebuilder Roofing/Siding 0 06-22-2010 06:41 PM
Can I use a framing nailer as a roofing nailer? capslock Tools 1 06-10-2010 11:41 AM
Roofing Nailer Gaskets benjamincall Tools 2 03-21-2010 10:12 PM
